Mavic Pro not stopping after takeoff
1184 11 2018-4-20
FinnPrints
Mavic Pro not stopping after takeoff and doing auto landing.
what's the solution ?
2018-4-20
A CW
Flight distance : 14237874 ft
Connect the drone to DJI Assistant 2 - refresh the firmware then calibrate the VPS/OA system using Assistant 2. Once done, let the drone cool down completely and take it to an area where there are no metal objects and calibrate the IMU. Take it away from the garage and calibrate the compass in an open area. If all of that fails - return it to DJI for repair and do not fly it.
2018-4-20
DJI Diana
Flight distance : 2408 ft
Hi FinnPrints, I'm sorry to hear about the issue that you are experiencing. As the floor 2# mentioned, please do the troubleshooting, change an outdoor open area where the GPS is good and no magnetic interference to try it again. If there is any further issue, please feel free to let us know and provide a screenshot of the error message, we'll look into it. Thanks!
2018-4-20
Suren
Flight distance : 13498560 ft
South Africa
I agree with Andy, looks to risky to fly if firmware, imu etc reset does not work.
2018-4-20
FinnPrints
The value of each product depends on the amount of its support.
Thanks for the support.
I restored the device to factory settings.
By Dji assistant 2.
And now it looks like everything is ok, at least in outdoor.
2018-4-20
B1houdini
Flight distance : 927927 ft
FinnPrints Posted at 2018-4-20 11:01
Glad to see you might of resolved the problem.
The DJI Support and DJI forum is the best place to start before you decide to send it back for evaluation.
Fly safe.
2018-4-20
Aardvark
Flight distance : 384432 ft
A CW Posted at 2018-4-20 01:31
" and take it to an area where there are no metal objects and calibrate the IMU."
Calibration of the IMU is not affected at all by the presence of metallic objects, it is however usually dependant on the calibration being done on a level surface. The compass of course needs to be kept clear of ferrous metals during calibration.
2018-4-20
Eug Drones
Flight distance : 152644 ft
Don't start the aircraft with the legs folded.
2018-4-20
davidmartingraf
Flight distance : 108805200 ft
It looks like it's overly sensitive to the throttle, and there also appears to be strain on the processor of the Mavic Pro, as it's performing actions very late once commanded. It looks like it just needs to be updated and reset, its memory and cache need clearing, and then those commands should be smooth and immediate.
2018-4-20
SparksBird
Flight distance : 10731690 ft
You still want to Calibrate the Compass, IMU and while at it the Gimbal.  It is good practice to especially calibrate the Compass especially if you go somewhere else to fly.  The compass make sure you are not near any metal objects.  A good open field should do the trick.  There are many great info and tutorials out there on how to do this if you have any questions.
2018-4-20
A CW
Aardvark Posted at 2018-4-20 15:42
I always recalibrate the IMU AFTER updating/refreshing the firmware. To be clear: -
1. Refresh the FW
2. Calibrate the VPS
3. Calibrate the IMU (due to the FW refresh)
4. Calibrate the compass in an area away from metal objects and any electro or ferromagnetism
I also tend not to keep my drone near any magnetic objects even when in storage.
2018-4-20
Suren
South Africa
That's good to hear, safe flying
2018-4-21
