Mapping with Agisoft Photoscan
2170 4 2018-4-22
mark vanhaze
Greece
I just bought the Mavic Air and want to know what is the best way to take photos for a mapping project using Photoscan.
Obviously I can fly manually but to get a solid overlap, can I use Dronedeploy to snap the photos?
2018-4-22
Tealk
Flight distance : 544222 ft
Romania
i use dronedeploy fo everything ...it is very easy to use...and autonomus..
2018-4-22
mark vanhaze
Greece
I tried Droneploy but it just wont see my Mavic Air. I have GO connect, then I exit Go, start Droneploy and it just cant see the Mavic. Is there an alternative to Droneploy? Is Litchi or UGCS any good?
2018-4-22
QuadKid
Flight distance : 482349 ft
mark vanhaze Posted at 2018-4-22 04:00
Litchi works well for visual mapping, a little labor intensive in Mission Hub if you are using Photos to map, also you would need to d/load the CSV file once the flight is complete to identify GPS coordinates with each photo taken if the client requires it.
2018-4-22
eried
Flight distance : 670823 ft
Norway
I had good results extracting photos from a video with the "point of interest" mode in dji go 4: https://forum.dji.com/forum.php? ... 670&fromuid=1099179
tried with litchi but I found out that the "programming steps" (like rotate x degrees, take photo, etc) were quite limited and buggy
2018-4-22
