Jenee 2
Flight distance : 7852129 ft
Latanzi Posted at 2018-4-23 04:27
Thanks Susan,
Yes I read that in the manual, also the note to never store batteries where temps may exceed 60°C. If I follow the guideline it is still OK to take off at 39°C, but that doesn't allow for any temperature increase in the battery due to flights, in fact anything much over 30°C doesn't allow for flight of any reasonable duration without hitting the 40 mark. I'll just keep monitoring and post when and if I get a warning. To date hottest temp achieved has been 52 after a 17min flight
The 40 degrees C is the ground temperature. Under most circumstances, it is going to be slightly cooler, the higher you fly. I regularly have battery temperatures up near 55 degrees C in the summer but have not had any problems yet. My batteries have all had nearly 80 charges and are still showing a 100% life. Just make sure you take the battery out of the drone after the flight and let it cool down properly before storing or recharging it. |
