Distorted photos and Video (wave affect)
1393 8 2015-5-9
platinum_survey
Flight distance : 3269032 ft
There is a major problem when taking a photo or video. Take a photo or video with the camera angled down, in the image you need to have the horizon in the picture. If you have a image showing the horizon you will see a wave affect in the image. The distortion is low on the left side, in the middle of the image it rises up then on the right side it drops down. It is a wave affect. It is best noticed when you have the ocean and the land in the image. Please try it and report you outcome. I was told to reset my IMU and this did not change anything. We have two Inspire 1 and they both have the same problem. I was also told that the only way it was going to be fixed to use photo or video software, this is not a fix.
For a product that is designed for provisional photographers it is unacceptable. I have sent image to DJI for review and waiting for a outcome.
2015-5-9
bostonlines
Flight distance : 1045558 ft
let's see it.
2015-5-9
peterconquest3
Are you using the ND filter? This often helps reduce picture artifacts by reducing the shutter speed. But yes, as bostonline asks... "Let's see some sample video".
2015-5-9
Marktho1
Yep I have 2 cameras, 1 from the first batch and 1 from the second batch... Both cameras have this distortion. All the footage I have seen online also has this distortion. I hope they can get it right with the next camera they come out with.
2015-5-9
platinum_survey
Send me your email address and to platinum_surveys@me.com and I will send you some photo.
The upload options is not working
2015-5-10
jimhare
Flight distance : 239035 ft
Yeah, this has been brought up before and there seems to be consensus that this is "normal" for the camera.  Not saying it's a feature or we have to like it, just that it's a consistent artifact that they will probably all do under the same conditions.
2015-5-10
platinum_survey
peterconquest3 Posted at 2015-5-10 12:43
Are you using the ND filter? This often helps reduce picture artifacts by reducing the shutter spee ...
Send me your email address to platinum_surveys@me.com and I will send you some photos.
2015-5-10
platinum_survey
platinum_survey Posted at 2015-5-11 08:49
Send me your email address to  and I will send you some photos.
I have sent Pete a copy of the photos and he has agreed that there is a problem.
2015-5-12
PlanetInhouse
I have this problem - I live on the coast and have several photos that have this bulge in the center of the landscape horizon.  The horizon also drops and curves right at the edges of the photos. Very dissapointed and hoping DJI will correct this. I have gathered several images and will provide them as examples if needed.
2015-5-26
