Processor overheated
3172 17 2018-5-6
N8m888
Flight distance : 80535 ft
Today I got the following error message appear “processor chip critically overheated.the aircraft is controlling its power consumption and will initiate RTH”
The message disappears after a second or two and normal flight resumes.
The fan is working.
Anyone else had this or have an explanation ..??
2018-5-6
Anuvis
Flight distance : 1976736 ft
80% percent it is a flase alarm.Dji go and spark have history on fake alarms such as no fly zone compas error for seconds etc...If you got that alarm frequent it is a problem .....
2018-5-6
Anuvis
You can check also if it is a false alarm by checking the flight log in the app run the specific flight if that alarm dose not apear in the flight then it is flase alarm
2018-5-6
N8m888
Anuvis Posted at 2018-5-6 05:12
Well yes looks like rales alarm !!!!
2018-5-6
DJI Elektra
N8m888 Posted at 2018-5-6 13:00
It seems that the fan is working well. Please do not feel worry about it. Any problem, please contact us again.
2018-5-7
N8m888
DJI Elektra Posted at 2018-5-7 02:41
Had another flight today and the error did not show up this time !!!
2018-5-7
DJI Elektra
N8m888 Posted at 2018-5-7 03:29
Sound great! Well done.
2018-5-8
djiuser_yyPeqAvHv2S3
Flight distance : 54032 ft
Processor Chip Critically Overheated.  The Aircraft will power off in 30 seconds.  It doesn't.  I'm trying to do the firmware upgrade in DJI Assistant 2, but that fails at 55% and gives Error Code 0x022403.  Please restart the device and retry.  I've done that a half dozen times and it's still not working!
2018-5-9
2018-5-9
S.J
Flight distance : 322454 ft
Kuwait
djiuser_yyPeqAvHv2S3 Posted at 2018-5-9 03:27
Are u having the SPARK in a hot environment. Also check if the cooling fan is working. How many flights have you completed ?
2018-5-11
BMelody
Flight distance : 3146 ft
Whenever I am working on or updating any of my aircraft I place a small electric fan a couple of feet away and blow some cool air over the bird. With a Spark have the camera facing the fan and will keep you from getting too hot.
2018-5-12
pedro433
India
I have noticed, that, with updating any of any aircraft or motor, if the processor cannot support the machine resume power, then the processor is getting started overheated with a short period of time, but for that, at the very first you have to go through with hp technical support number to check the processor configuration and is it suitable with the situation or not!
2018-9-1
johncater
India
2018-10-5
manish00
India
HP Envy Printer offline error may be annoying but it has the simplest solution. The error may occur due to network conditions or some other technical problems.
Once done with care, you will never bump into these sorts of issues.
2018-11-3
N8m888
manish00 Posted at 11-3 04:20
2018-11-6
Jos A
Flight distance : 73209 ft
which version of the app?
2018-11-6
manish00
India
When the http://www.hp-online-care.com/hp ... ine-windows-10.html[/url] says offline in windows 10 because printer wireless system is not working properly or there might be computer related issues. Anyone can easily recover from this problem by this most simple step "restarting your Wireless Router and after that restarting your computer."
2018-11-19
N8m888
manish00 Posted at 11-19 00:35
When the HP Envy 4520 printerhttp://www.hp-online-care.com/hp ... ine-windows-10.html[/url] says offline in windows 10 because printer wireless system is not working properly or there might be computer related issues. Anyone can easily recover from this problem by this most simple step "restarting your Wireless Router and after that restarting your computer."
what has an error with a dji spark drone got to do with an HP printer and windows 10 ??
2018-11-19
