Mavic pro only goes up after return to home
elmantukas
Flight distance : 45709 ft
Hello everyone
So I have been trying out the mavic pro return to home feature, but all it does it faces the home direction and starts going up, and continues to do so to 500meters but never even bothers to go home, ive tried sorting the settings and its 50 meters, everytime before flying i take off and  i allow it to get gps connection and set the home point, also calibrate the compass before any flight, and still it behaves in such manner, is there something im not doing right? cause if i loose connection i loose the drone 100% now...
2018-5-6
G_Sig
Flight distance : 9109311 ft
Iceland
Upload your flight log from your device here phantomhelp com/LogViewer/Upload/
and post back the link.
2018-5-6
elmantukas
It would appear that there is an issue with my obstacle avoidance, I turned it off for RTH and now it comes back without any issues.
2018-5-6
QuadKid
Flight distance : 482349 ft
Another thing to remember is that the sun hitting the OA front sensors can stop the drone dead in it's track until you yaw it away from the sun.
2018-5-6
SparksBird
Flight distance : 10731690 ft
Also try to calibrate the IMU as well.  Maybe try to wipe off the bottom and front sensors.  Are you on the latest Firmware?  DJI GO 4 app latest?
2018-5-6
B1houdini
Flight distance : 927927 ft
elmantukas Posted at 2018-5-6 15:24
I agree that could be your problem.(OA and the sun). If it is facing the sun at the right angle and you hit RTH the MP might  halt ,rise about 15 feet and try to go forward. It happen to me while the sun was low in the sky. I hit RTH and the MP started forward ,stopped and rose, stopped again and then rose again. Once it got really high I canceled RTH, turned the drone around and came home backwards. Now that I am aware of the problem I keep close tabs on the suns location in the sky when I fly. I sometimes will turn off OA before I bring it home.
2018-5-6
DJI Thor
Flight distance : 13602 ft
Does the OA system work normally when it is not in RTH mode? Facing directly to the strong light might enable obstacle braking of the drone. So please try to shut down the forward sensors if it needs to fly towards the strong light, but be cautious since the OA system is not working.
2018-5-13
