How do you wipe an SD card?
954 3 2018-5-24
brianoflondon
Flight distance : 1163743 ft
Israel
What's the best way to wipe an SD card? I can't format it in the DJI (If I do that it is unreadable in my Macs except by attaching the drone by wire).
I've tended to be deleting all the files in the 100Media folder but I'm suspecting that's not so great. On one of my cards I have a 74meg clip that is ALWAYS there to be imported no matter how many times I've deleted all the files!
I'm starting to think I should just use Disk Util on the Mac to erase the disk and reformat at it as exFAT each time.
Any comments?
2018-5-24
rent
Flight distance : 1773458 ft
Russia
Are you saying if you format the SD card while it's in the drone, then later insert it into your Mac, your Mac can't read the card?
If that's the case, that is quite strange. May I ask the model and OS version of your Mac?
2018-5-24
DJI Stephen
Good day. I understand that you are asking what will be the best way on how to format your SD card. I've looked into this and the best way for us to format the SD card is by unmounting the SD card from the drone then use a card reader to connect it to the computer. From there try to use Disk Utility to format your SD card. Thank you.
2018-5-24
brianoflondon
Israel
rent Posted at 2018-5-24 09:10
Yup. Sandisk Extreme Pro 32GB cards, if I format in the Mavic Air I can't read them on both my Macs using their inbuilt card readers (and the micro SD to SD card adapters).
Macs are
iMac (Retina 5K 27-inch 2017)
MacBook Pro (Retina, 15-inch, Mid 2015)
I've posted about this before.
2018-5-24
