DJI Assistant 2 not connecting
5859 14 2018-5-26
Trailblazer5715
Flight distance : 1821880 ft
I have downloaded DJI Assistant 2 v1.2.4 onto my Windows 8 PC but it will not see my Mavic Air or the RC. When I look at hardware in the control panel indications are missing or unrecognized drivers. Any ideas what the correct drivers are and where I can get them (or any other ideas)? I have already tried an uninstall and  reinstall of DJI Assistant 2. Thanks for any help you can provide.
2018-5-26
Suren
Flight distance : 13425892 ft
South Africa
Try another usb cable or another pc
2018-5-26
Trailblazer5715
I don’t have another PC to try but will try a different cable although this cable does transfer images and videos. Thanks.
2018-5-27
DJI Thor
Flight distance : 13602 ft
Sorry to hear the difficulties. I will forward you a driver for trying if you are interested in. Please let me know if you would like to try. Thank you.
2018-5-27
Trailblazer5715
Yes I would like to try another driver. Thanks.
2018-5-28
saviour
Flight distance : 604203 ft
DJI Thor Posted at 2018-5-27 22:47
Could you send it to me too please?
2018-5-28
DJI Thor
Trailblazer5715 Posted at 2018-5-28 03:42
The driver is sent via DM. Please connect the RC to the PC and keep the RC powering on when installing the driver. Then restart the DJI Assistant 2 and the RC and connect again. See if it helps.
2018-5-29
DJI Thor
saviour Posted at 2018-5-28 04:42
Yes, I had sent the driver via DM. Please refer to my reply on 7#. Hope it works for you.
2018-5-29
Trailblazer5715
DJI Thor Posted at 2018-5-29 19:54
Thanks for the link and instructions. I was finally able to try it and was successful connecting to my Mavic Air and completing a calibration but the RC was not recognized. This accomplished my goal of calibration but would consider it a plus if it would also connect to the RC. Thanks.
2018-6-3
DJI Thor
Trailblazer5715 Posted at 2018-6-3 06:32
If you had tried the RC driver I provided but it doesn't work, you might need to check the driver of your PC. Or you can try another PC if it is convenient.
2018-6-4
joe_gadget
Same - mavic recognised but not the controller. had to update the controller via wifi.
2018-6-4
DJI Thor
joe_gadget Posted at 2018-6-4 05:11
Update the RC via WiFi also works. I had also PMed you the link to the driver just in case you need it. Please refer to my reply on7# when installing it. Thank you for your attention.
2018-6-6
Jerkman
Flight distance : 197054 ft
I am trying to connect my Phantom 4 Pro V2.0 to the DJI Assistant 2 application but am also having no luck.  I am seeing a message that my Phantom's vision system needs to be recalibrated.  I've tried on two Macs and also on a Windows VM with no luck.  I see the message that says I need to plug my device in, which I do, and the message never goes away.  I am able to browse files on the Phantom's memory card through the connection.  Any ideas?
2018-8-30
Jerkman
Jerkman Posted at 2018-8-30 08:43
OK, the problem was that I was using the incorrect version of the Assistant 2.0 program.  I didn't realize that there were different versions for the different models.  As I'm flying a Phantom 4 Pro V2.0, I needed to grab the Assistant version from https://www.dji.com/phantom-4-pro-v2/info#downloads
Stupid mistake, I know....
2018-8-30
djiuser_L5eXMdiRkK7R
Seychelles
Hi
I'm currently using window 8 and I have downloaded the mavic assitance 2 for my mavic 2, but the window is not recognise my drone.
Any idea. Please
2018-12-3
