Brad Bilger
Flight distance : 14843274 ft
Finally had an error on my Mavic Pro that I got a problem figureing out. I found references to it in the forum, but not a good explaination as to what it is. I got 293 Flight Times, 4,290,489 Feet (1,307,741 Meters) and never a crash or even a bump. Warm day, partly Cloudy, winds out of the west at about 5 mph. Third flight of the day. Home point is set, 19 Satellites in view. Battery at 100%. No error messages on screen. I take off and get 343 Feet out and 113 feet in altitude in 35 seconds. Suddenly the controller chirps and says "ATTI Mode" and a Disconnnect and the view on the screen looks like it's leaning to the left about 45 Degrees. (No idea if Gimbal acting up or if the AC is actually leaning to the left. Not enought time to visually check) Rather to be safe than sorry, I punch the RTH button and the AC turns, lines up, heads back and lands perfectly. I shut everything down, and restarted the app and the AC again and then flew for the remainder of the battery staying close without a single bug.
I get home and download flight records and send to Phantomhelp.com. Readout shows 4 entries starting at 35.3 Seconds stating "Speed Error." No mention that I can find of a Disconnect. All Firmware totally up to date, App is version 4.2.16 (Android) Device is Samsung Note 5.
Flight records located at:
http://www.phantomhelp.com/LogViewer/A2WD7W4Z6EQ36LPQRBDH/
Anyone got an idea or was this just a fluke???
