Compass REcalibration
940 8 2015-5-13
disilvers
I plan to fly my P3 in two locations that are less than 2 miles apart.  Is it necessary to recalibrate the compass when I move between these two locations or are they close enough that compass would stilll be accurate?
2015-5-13
gil
Flight distance : 1379308 ft
My recollection is if you've gone more than 10 miles you should re-calibrate.   But hey, when in doubt...
2015-5-13
jacmac64
I re-calibrate every time I fly. It only takes a minute or less and i don't want any problems because i wanted to save a minute.
2015-5-13
Fulgerite
You should recalibrate before each flight.
2015-5-13
Total
Flight distance : 336480 ft
Now I re-calibrate the compass BEFORE every flight .  I would not get consistent  hovering if I did not do it every time ....
2015-5-13
imdjay
Flight distance : 194541 ft
seriously, just recali every time you move even a few hundred feet, it takes less than a minute.
2015-5-13
TomWolves
Flight distance : 110577 ft
I recalibrate before every flight, just to be safe.
2015-5-14
scrufytam
Flight distance : 1026309 ft
I always calibrate between every flight. Even if its the exact same location.
2015-5-14
jeff.wyman.mac
Flight distance : 3194669 ft
scrufytam@gmail Posted at 2015-5-14 19:34
Recalibrate before each flight (usually) . . . .
2015-5-14
