EdisonW1979
Flight distance : 1535679 ft
tiagosaraivacg. Posted at 2018-5-31 11:45
today when flying had this kind of problem too.. was making a straight upward flight with gimbal pointing down. and as I was climbing i started moving gimbal up, but from all sudden the AC just moved yaw to the left without any input from my controler. I instantly landed my MA, anyone with this kind of problem? not first time happening, even had some flights without any problem of that kind. should I be worried?.. neverless the all shot was screwed after that yaw move, and didnt tried it again.
This seems to be an issue with the latest MA firmware .0400, see this thread:
https://forum.dji.com/forum.php? ... D534%26typeid%3D534
Some people here will claim there is no issue, but there is, and DJI is aware of it and supposedly working on a fix, but taking their sweet time so far.
I'd suggest you refresh the firmware via DJI Assistant 2, not OTA, and then recalibrate everything... First restore to factory settings via Assistant, then recalibrate VPS using Assistant, then find a PERFECTLY FLAT (like measured to be flat with bubble levels flat) surface to redo your IMU calibration, then go outside and recalibrate your compass and gimbal.
You "should" be ok after this, until DJI fixes the issue.
Good luck! |
