Wifi Channels No Show
1919 21 2018-5-31
Sashi
Flight distance : 1469705 ft
Japan
Hi, I have a question and seems could not find the answer on Google.
Why does my Wifi Channels under the Wifi Setting missing?
Could not also select either 2.4 or 5.8 ghz (no option).
Either via OTG or Wifi connection, no Channels and the bars.
Hoping for your guidance.
Happy flying!
2018-5-31
S-e-ven
Flight distance : 5922034 ft
Thailand
How about some screenshots, please?
2018-5-31
Sashi
Japan
2018-5-31
DJI Susan
Hi Sashi, may I know which mobile device do you use? What's the current aircraft, controller and APP version? Does the issue remain if change to another mobile device?
2018-6-1
Sashi
Japan
DJI Susan Posted at 2018-6-1 02:53
Hi, thanks for your reply.
Anyway, the devices that I use with my Spark are IPhone 8, Samsung S8 and Samsung Tab A7.
My spark, the controller and app are in the latest firmware/version.
Yes, the issue remains regardless of changing from one to another devices mentioned above.
Hoping for your help.
P.S. I tried downgrading, refreshed the current firmware, forced stop the app, clear cache the app, restart the phone, still nothing.
P.P.S Whenever I use the Iphone 8, only the Wifi SSID, Password is shown. No channel mode graph.
2018-6-1
Sashi
Japan
Any help, please.
2018-6-2
DJI Susan
Sashi Posted at 2018-6-1 07:37
Received with thanks! I'll forward to our engineers for review, and come back as long as there is an update.
2018-6-10
Sashi
Japan
DJI Susan Posted at 2018-6-10 01:26
Please and thank you, DJI Susan.
2018-6-10
pmshop
Flight distance : 8073271 ft
Just a shot in the dark, refresh the firmware WITH the controller connected...
And just had to ask, you are NOT using OTG on either configuerations?
Also, what is your country location?
2018-6-10
Sashi
Japan
pmshop Posted at 2018-6-10 05:19
Thanks but it didn't work.
Though, I will try to factory default the Spark tomorrow. Will see if that would fixy issue.
Thanks again for your reply.
2018-6-10
DJI Susan
Sashi, I just got an update from our engineers that they need more data for analysis. Please refer the tutorial video and export the black box for further analysis, thanks in advance!
2018-6-14
Sashi
Japan
DJI Susan Posted at 2018-6-14 22:50
https://youtu.be/ngEHdAlAh9A
Hi, sorry it took awhile. Will follow procedures. Thanks. Will update again once done.
Really appreciate it.
2018-6-20
Sashi
Japan
There seems to be a problem with that file. Could not save it, been trying several times.
So, I just tried to save the other without it. Just giving you an update so far. Thank you.
2018-6-20
Sashi
Japan
Could not save few of the files, same error is showing after my last post.
Anyway, saved just a few and now, looking for the DJI Server.
Hoping for your guidance. Thanks.
2018-6-20
DJI Susan
Sashi Posted at 2018-6-20 06:11
May I know what's the current version of the DJI Assistant 2? Please try to reinstall or refresh to see whether it helps.
2018-6-28
Sashi
Japan
DJI Susan Posted at 2018-6-28 03:14
Thank you for your response.
The version is the latest, I think. V 1.2.4.
2018-6-28
Gunship9
Weird.
I thought the WiFi channel analyzer was scroll-able.  Did you scroll off (swipe by) the used channels with noise to unavailable channels?  There are dozens of channels and Spark doesn't have all of them available for use.
Maybe something wonky with manual or auto channel selection.  No Fly Zone updated so it knows what channels are available in your area (database updated for analyzer to populate x axis of the spectrum graph)?
2018-6-28
Sashi
Japan
Gunship9 Posted at 2018-6-28 06:06
Weird.
It was but after trying the Litchi app, this happened.
On a android phone, you could see the graph table only, no channels/bars whatsoever though. On an IOS device, is a different story. It has no graph table at all, all you could see is the Wifi name and password of the AC.
Basically, I cannot see, know and change what channel I am or to use. Either 2.4g or 5.8g.
Thanks
2018-6-28
DJI Susan
Sashi Posted at 2018-6-28 03:24
Thanks for getting back to us. Please refer above and try to reinstall the DJI Assistant 2 and refresh to see whether it works. If still no luck, I'm afraid that you may send the unit in for a fully diagnosis.
2018-6-30
Sashi
Japan
DJI Susan Posted at 2018-6-30 23:28
Greetings, Ms. Susan.
Thank you for your support and guidance.
Fortunately, I was able to find a fix and I am again, loving my Spark.
Thanks and more flying!
2018-7-3
DJI Susan
Sashi Posted at 2018-7-3 03:45
That's great! Would you mind sharing us with your fix? We'll keep learning and avoid similar issues if applicable.
2018-7-7
fansde975589
Flight distance : 372648 ft
Israel
Hi
I have purchased a new Dji spark and im having the same issue
No Inf bars or any way to swich Wifi Connection (im not using OTG Cable)
the only time i can see the bars is when im connecting the spark directly to the Phone(Samsung note 5)
i also tried I phone X,Ipad and other android deviced but nothing is showing up
latest firmware on Spark and Remote controller and dji go app
i tried to  downgrade the app to 4.1.15 and 4.1.12 and still nothing
also i tried to downgrade the firmware on the AC Spark and still nothing
also i tried to refresh dji spark firmware and still nothing happened.
when i tried to refresh the controller firmware i also discoverd that it wont connect to the PC
No beeping sound of connection or disconnection and nothing, i even checked on device manager and theres nothing showing up.
its really sucks i just bought it a week ago and i already need to send it over to dji to seewhats worng with that since i checked about this problem and it isnt normal
not to mention that its hardly passing 30meters away from me
2018-11-21
