Dji Spark RC calibration fail.
2233 11 2018-6-22
naumoves
Russia
Hello. I have a problem with my spark rc.
Today I`ve decided to try my spark rc calibration. I have done everything like in youtube tutorials. But at the moment when i`m pushing calibration button, start button pressing automatically. Then I move sticks as indicated on screen and repeat but nothing happens. Button "next" unavailable. Does it mean that my rc is ok and I don't need recalibrate it? P.s. There are all "zeros" in calibration squares for both sticks. Please help. And sorry for my English. Thanks!!
2018-6-22
DJI Natalia
Sorry for the trouble caused to you. Is there any message showing up on your screen while performing the calibration? Also, if you do have the screenshot kindly post it here? Thank you.
2018-6-22
S.J
Flight distance : 322454 ft
Kuwait
Normally u never have to do a RC calibration unless u had a major damage with the RC.
I wonder what was the reason to recalibrate the remote controller .
2018-6-22
naumoves
Russia
1st photo - before calibration. 2nd - after pushing "Calibrate" button. 3rd photo - after pushing "Calibrate" in popup window. Button "Start" starts automatically. Then I move sticks as indicated.... repeat... and nothing happens. I`ve decided to try every functions of spark to be aware how it all works.
2018-6-22
Mirek6
Flight distance : 609724 ft
RC calibration on Android is unreliable and finicky. You need to wiggle your control socks back and forth along the blue circle path to keep the blue circle moving clockwise. In my experience it is trial and error. Try to move your sticks one at a time, not both. When blue circle is stuck try to slightly reverse movement of the sticks and push forward again - wiggle back and forth until blue circle starts moving again.
I have seen multiple threads in the past on this forum complaining about difficulty in calibration of RC using Android. I have Android device and I had the same issue which I resolved by doing steps I described above.
2018-6-23
LAKEHOUSE
Flight distance : 9708 ft
DJI Natalia Posted at 2018-6-22 15:04
Same issue
2018-7-1
DJI Tony
Hi, sorry to know that you're having the same issue, did you manage to turn off the aircraft prior to the calibration? Would it be possible if we can provide a short video of the issue? You can use google drive or dropbox then provide the link so that we can check it for you.
2018-7-1
andrzej
Flight distance : 10449 ft
Poland
DJI Tony Posted at 2018-7-1 12:44
Is that case solved already? I have same issue.
2018-7-8
Drone_Soarer
andrzej@rezler. Posted at 2018-7-8 10:09
Same issue for Me too.
2018-7-27
dudez7
Flight distance : 741778 ft
Singapore
Me too on Android.
2018-7-27
Stephane22
Flight distance : 137890 ft
same here  galaxy 7 edge and lenovo tab2
2018-8-1
Joller79 DK
Flight distance : 26447 ft
Denmark
No issue on huawei p10 lite, other then i had to circle the sticks quite some times,
I just press calibrater, and circle stick clockwise until done.
2018-8-1
