Mavic Air: is there a way to get 120 fps footage to tag as 24 fps instead of 30?
2681 11 2018-6-25
Grapejuice Pix
I absolutely love that it tags the 120 fps footage as 30 fps so I can see it in slow motion without having to do anything to it.
Having said that, I shoot in 24fps. I’m a filmmaker, I got the Mavic to be able to add drone shots to my films, and I also just think 24 looks better than 30.
Obviously when I drop the 120/30 fps footage into a 24 fps sequence I just have to render it and it’s fine. But I have an old computer and the less rendering I have to do the better.
So is there a way? Thanks!
2018-6-25
A CW
Flight distance : 15283773 ft
Not that I'm aware of but would be good to know.
2018-6-25
TexasAerials
Flight distance : 566952 ft
shoot at 96fps?  it would give you the same 4/1 slowdown ability and you wouldn't have to use optical flow to interpret the out-of-time frames.
2018-6-25
TexasAerials
Just remembered that another youtuber posted a video about how to make the spark 30fps video work better in a 24fps timeline.  He suggested that you could drop your 30fps video into the timeline and set it to play at 80% of original speed, which would make the 30fps line up with the 24fps timeline, while giving the video a bit more of a cinematic quality.
2018-6-25
Grapejuice Pix
TexasAerials Posted at 2018-6-25 11:00
Thanks for your suggestions. I’m more worried about having less rendering time than anything else to be honest. That’s why I was hoping there was a setting you could change or something.
2018-6-25
RGMGFitness
Flight distance : 233757 ft
Grapejuice Pix Posted at 2018-6-25 11:07
If your using Adobe Premiere Pro CC 2018 for your video editing you can change the 'Sequence Settings' to whatever frame rate you want it to be.
2018-6-25
A CW
That's good to know too - thanks for sharing
2018-6-25
TexasAerials
That is probably the easiest way to do it without adding a ton of render time with optical flow.
2018-6-25
Grapejuice Pix
RGMGFitness Posted at 2018-6-25 11:16
[view_image]
Usually I’m dropping a slow motion shot into a 24 fps sequence. Thanks though.
2018-6-25
TheFrenchDrone
Flight distance : 3687441 ft
I think there's not much solutions because rendering time depends a lot of the power of your computer. For a smooth editing you can use proxies (works on FCPX and PP) but it won't change anything when you want to export your video later.
2018-6-26
CemAygun
Flight distance : 810 ft
Turkey
As far I know the only way of doing what you want is to remux the video with the new (desired) fps. This does not touch the video stream, only effects the container. So it is much much faster than re-encoding, and there is no generation loss. You can use something like "mkvmerge" if you are comfortable with using the mkv container...
PS: You can remux to any container you choose of course, none being preferable over the other for the intended purpose...
2018-6-26
abuttig
Flight distance : 75912 ft
Mexico
Conform your 120fps footage to 24fps and then choose create sequence from clip and you will have slow motion 120 fps on a 24fps timeline.
2020-4-26
