Marcus_R
Flight distance : 282077 ft
KurtVD Posted at 2018-6-30 18:18
1) yes, connecting your iPhone to the RC via cable will provide a much better experience, eg a more stable connection and a better range, since the RC will only have to maintain a WiFi connection to the aircraft, and not two WiFi networks simultaneously. For best results, choose a channel from the 2.4 GHz network manually (carefull to select one that isn’t too busy, there’s a graph in the WiFi settings of the app that shows the state of all the channels)
2) I’m not 100% sure about US regs, but I’m quite sure the altitude limit is everywhere, just like in EU countries. It’s to avoid incursions into airspace where manned aircraft fly, which would be extremely dangerous.
Kurt. I think you have a mis understanding about how the connection works. If you are using the controller, all communication from the spark is between the controller and the spark. Even the video. The phone gets is video sent from the controller via wifi or OTG. While using the OTG cable will improve video lag on the phone, it will have zero impact on the connection to the drone. All your doing is improving the connection between the controller and the phone, not the spark and the phone. and definitely not the controller and the drone. You can prove this by actually flying without the phone, not that you would. |
