hallmark007
Flight distance : 10017858 ft
I believe many use them , how successful they are is not really known, if you using with Mavic Pro , you can put it on the nose of the aircraft, don’t put on top of rear as you will block GPS receiver, also anything metal added to your drone will have some effect on your compass , so it’s advisable to calibrate with tracker on, and if you fly with it off calibrate again. |
