Mirek6
Flight distance : 609724 ft
gabrielsturmer Posted at 2018-7-16 08:23
I check all the boxes. No metal, no watch, no metal structures around, grass field, no belt buckle and I was watching my phone from about 3 meters away.
Also, my firmware is ok, the video is from someone else.
OK, understood.
Here is what I would do.
Even if your firmware is OK but Spark shows this abnormal behaviour, I would reset Spark to factory settings and re-install firmware. After that I would try and calibrate compass one last time.
I have seen cases where really weird behaviour was fixed by resetting Spark and re-installing firmware. I know that it does sound like magic, but this is a very complex piece of technology and software and things may, and do, get mangled. It's the same as with your PC - if something does not work - reboot. If reboot does not work - reinstall. If reinstall does not work - cry for help :-).
Of course, I cannot guarantee that it will help. But it may.
If this fails and you still have a problem, open the case with DJI and request Spark replacement.
At least you will be convinced yourself that you did everything you possibly could.
Good luck and let us know.
Mirek |
