Firmware fail on spark
2831 17 2018-7-26
Dug0
I tried to update my spark today? the spark updated successfully. The remote failed. After that I tried again but the remote does not show up in my wifi list. The red light on the remote flashes twice  non stop.. I tried holding the power button for 9seconds , it beeped three times then went back to two flashes. It's like the firmware upgrade broke the wifi. Before this the remote connected to the spark just fine. Is there a way to get the wifi working on the remote.
2018-7-26
DJI Paladin
Flight distance : 318 ft
Hi there, sorry for the inconvenience. May I know if you are using Android device? If yes, Kindly try connecting your mobile device using an OTG cable. Did you receive an error message on the APP?
2018-7-27
Dug0
DJI Paladin Posted at 2018-7-27 07:42
I am using android. No error message other than update failed. I have tried an OTG cable and got nothing to indicate it's has been plugged in nor does it connect to my phone or android tablet.  I can connect to the spark and fly it without the remote, so I know the spark and the ap on my device do work. When you power on the remote the red led flashes twice waits a second and flashes twice again. It does this non stop and after about 5 minutes it also starts to beep non stop.  The remote's wifi does not show up on any device. Thanks for the help.
2018-7-27
S-e-ven
Flight distance : 5922034 ft
Thailand
Have u used a OTG before for flying?
Just to verify that the direction is right, I mean.
The RC has to be the host, the phone is the "USB-device on the go" here
I had the same LED blinking, after the update via wifi failed twice.
I then used a cable and the update came through.
Good luck
2018-7-27
Dug0
S-e-ven Posted at 2018-7-27 09:39
Is there something I need to do on the phone to recognize the sub cable.  Could you explain more on the remote being host. Thank you
2018-7-27
Dug0
Dug0 Posted at 2018-7-27 09:52
USB cable. Darn auto fill
2018-7-27
S-e-ven
Thailand
If you use a OTG adapter, it is easy:
The micro of the adapter has to go into the RC
2018-7-27
Nate The Great
Dug0 Posted at 2018-7-27 09:53
I have the same issue. RC failed to update the firmware and now it will not connect to Wifi.
I plugged in the OTG cable to the remote, did the 10 sec hold and I can downgrade the firmware it lists 1000 down to 70x.
I tried to update again and no luck. I tried to download the DJI assist on my PC and it does not show anything connected (Spark or remote)
So I am kinda stuck and not sure what to do. I am curious if I should just downgrade all the firmware to a older working version. I think i spent over 4 hours working on this so far and I am frustrated and confused.
2018-7-27
S-e-ven
Thailand
The fw of the spark is (imho) best up-/downgraded on pc with assistant 2, but can be done via wifi and via  RC,too
I just wouldn't do the Spark fw update via RC, anyway! if with device, direct wifi fo Spark!
The fw of the RC is (afaik) only possible via direct connection to a device, wifi or otg.
2018-7-27
Dug0
Nate The Great Posted at 2018-7-27 10:21
I can not get the OTG cable to work before or after the fw upgrade.  The wifi worked before the fw upgrade but not after it failed. I just spent 2 hrs on the phone with tech support and tried everything. They took my contact info and said they would need to research this and would get to me in a couple of days. It appears the update bricked my remote with the red light double flash of death.  I am left waiting on tech support to get back with me. Will post the results. If anybody has a solution please post. I have only had this for three weeks and I'm very frustrated.
2018-7-27
wimherman
Flight distance : 208556 ft
Norway
Here is a whole recent topic abt this issue: https://forum.dji.com/thread-157776-1-1.html
2018-7-27
S-e-ven
Thailand
Dug0 Posted at 2018-7-27 12:20
"I can not get the OTG cable to work before or after the fw upgrade."
So you can't prove right now, if you COULD finish the fw update with otg to the RC.
That is unfortunate!
2018-7-27
S-e-ven
Thailand
Oh: Your droid is a ....?
2018-7-27
Dug0
S-e-ven Posted at 2018-7-27 19:11
I tried 2different OTG cables and 2 different android devices. None worked. I think it is time to send it in
2018-7-28
Nate The Great
Seems like the firmeare update sabotaged some devices. My spark is out of warranty I will just have to see if i can firmware roll back
2018-7-28
Alexey Batalov
Flight distance : 21105262 ft
I know that you can downgrade firmware of the ac from dji ass2, but how do you downgrade firmware of the remote??? Dji ass2 doesnt recognize the spark remote...
2018-7-28
ahmedalqassem
New Zealand
S-e-ven Posted at 2018-7-27 10:19
[view_image]
Have you tried it yourself and it worked? It didn't work with me
2018-7-28
S-e-ven
ahmedalqassem Posted at 2018-7-28 14:23
I use otg for about a year, now. Almost exclusively.
But this "easy" was meant for the directional thing and to someone who hasn't used otg before this update.
I just plugged my cable in like  the hundred times before and it worked for the update.
And if it had not worked, I would have known that it is  a bricked by update - RC, not a otg connection failure.
2018-7-28
