1.1.9 Update Startup Jingle
1898 12 2015-5-23
gurnpj
Flight distance : 103609 ft
When updating my P3P to v1.1.9 my P3 sounded off the startup jingle. I don't know if anyone else had this happen or if that means something isn't updating correctly but just thought I would bring it up.
2015-5-23
gurnpj
Alright so it finished updating and seems to have been successful. This was the first time that it was sounding off the startup jingle all the way through so I was a bit confused but everything seems to be in order.
2015-5-23
bluetazmaster69
That's good to hear.
2015-5-23
aburkefl
Flight distance : 78612 ft
gurnpj@gmail.co Posted at 2015-5-23 23:57
Alright so it finished updating and seems to have been successful. This was the first time that it w ...
I experienced pretty much the same thing. I did a double-take when, in addition to the expected buzzing, it sounded like it was booting up. I think I heard that happen twice. Like you, it scared me, but everything went quite smoothly. I used my new 64GB card also - worked like a champ.
One pleasant surprise on my side. I've never been able to find the calibration screen for the camera angle control. I've never been able to get the camera to go up very high beyond parallel. This morning, after the 1.1.9 update, when it booted, the camera looked like it was angled pretty high. I looked at the app and moved the camera adjusting wheel - success! It now goes the entire 30-degrees up, goes straight down, etc. I used one of those buttons on the under side of the controller to flip the camera between straight down and parallel. Can't see too much need for pointing up too high - the props tend to get in the way very easily with any serious up-angle.
2015-5-23
derekoneill99
I've updated my P3 with the lasted firmware,  now on startup  i get a sound d-dd only once, is this normal
2015-5-24
derekoneill99
Ive updated the lasted firmware on my P3, now on startup i get a d dd sound once. Is this normal
2015-5-24
Total
Flight distance : 336480 ft
This is normal since you have the latest firmware on your micro card..
2015-5-24
gurnpj
derekoneill99@e Posted at 2015-5-25 01:12
I've updated my P3 with the lasted firmware,  now on startup  i get a sound d-dd only once, is this  ...
This isn't "normal". I have updated my P3 through three firmware updates now and that has never happened, nor have I ever heard it happen. I suggest formatting the card to remove the firmware file and see if it still does it.
2015-5-24
derekoneill99
But do I not need to keep the firmware update on the SD card to update future battery's?
2015-5-24
Total
It is NORMAL if you have the latest firmware on the sd card . And YES DJI says to leave the latest firmware on the card to update future batteries .....
2015-5-24
rogeruzun
Flight distance : 325659 ft
I am updating mine now and periodically it's playing the startup jingle while it's updating.  It's doing the D-D-D-D sound and then every min or so the startup jingle.  Its still in the process of updating.
It updated normally despite playing the startup sound periodically during the update.
2015-5-24
TomWolves
Flight distance : 110577 ft
Why not have two SD cards?, one maybe 4GB , and one 64GB, keep the latest firmware on the 4GB, and use the 64GB for videos & photos.
2015-5-25
Fulgerite
Yes...  I noticed the "motor arming" tones happened about three times during my update.  The LED's turned off near the end as well.
2015-5-25
