First Gimbal
560 3 2018-7-31
PhoenixUnBound
Hi, the Ronin-S is my first gimbal and im trying to balance a Sony a6300 with a kit lens on it. Having a ton of problem trying to balance it, especially the tilt axis. Any tips.
I've also watched a ton of videos and have  theoretically learned how to balance the camera but can't get pass the tilt axis
2018-7-31
PhoenixUnBound
I can balance it pretty well on the tilt axis horizontally, but vertically balancing is a challenge. 2 days at this so far
2018-7-31
Hi PhoenixUnBound, sorry for the troubles on balancing the tilt gimbal, did you try to mount the Riser Plate to see if it helps?
2018-8-1
PhoenixUnBound
DJI Mindy Posted at 2018-8-1 02:46
The riser plate is attached. I had my Rodes mic attached and it helped with balancing it, but it doesn't fit so(roll axis is in the way) its been tough balancing it. The riser plate does help some. Just not sure if im placing the riser plate correctly on the ronin-s plate(the manfrotto style plate) that comes with the ronin-s
2018-8-1
