Attaching cable to controller
820 7 2018-8-12
PatrickW
Flight distance : 14921 ft
New Zealand
What is the procedure for fitting the little usb cable to the controller? It came with an iPhone one fitted which I have removed and need to fit the USB C one. There is a little rectangular insert that looks like it should go into the side of the controller for the usb plug to sit in but I cant get it in and I dont want to break anything.
Any instructions appreciated.
2018-8-12
Kingram
Flight distance : 84085 ft
This might be what you need-
https://www.amazon.com/Apple-Mic ... o+Lightning+adapter
2018-8-12
PatrickW
New Zealand
Kingram Posted at 2018-8-12 17:09
https://www.amazon.com/Apple-Micro-Lightning-adapter-MD820AM/dp/B00WVDGSKU/ref=sr_1_3?ie=UTF8&qid=1534122460&sr=8-3&keywords=Apple+Micro+USB+to+Lightning+adapter
Thanks. I have the cable and the insert, its just that I am not sure how the insert slider thing is supposed ro attach to the side of the controller, do you just push it in?
2018-8-12
GDL
Flight distance : 2768694 ft
Singapore
Yes, Just push it in.
2018-8-12
PatrickW
New Zealand
GDL Posted at 2018-8-12 17:15
Thanks, got it in. I didnt want to break anything before I had a chance to fly it
Now to wait patiently while the batteries charge.
2018-8-12
Free2be
Flight distance : 229570 ft
Take your time and control all the settings before start to fly and even in a open space! Successsss!
2018-8-13
Mullheliflier
Flight distance : 12305135 ft
I prefer to use a stronger cable plugged into the bottom USB socket (removing the side one). Some also find it easier to use the small side cable without the plastic slider.
2018-8-13
Charissa
Flight distance : 689334 ft
South Africa
Personally, i found that little sliding thing a problem. It always pops right back out if i try to connect my phone. I removed it totally. I also use the bottom usb for the phone, and the top one with a power-bank to charge the rc if I plan to take a couple of batteries and my phone is not fully charged. Works a charm.
2018-8-13
