New Mavic 2 Firmware Released (11/23/2023)
42938 287 2018-8-24
DJI Susan
fansc7fff6c1 Posted at 2018-9-8 09:32
Is IPad Air 2013 or Samsung S8 2017 works with DJI GO 4?  Thinking to buy MAVIC 2 PRO.
Hi there, you may check the recommended list from here: https://www.dji.com/mavic-2/info#downloadsFor the mobile devices not in the recommended list, you may test in the local store before making the decision.
2018-9-10
DJI Susan
soccerace21 Posted at 2018-9-8 11:55
I've not been unable to update my firmware since I got the Mavic 2.  If I try on the phone, it gives me a network disconnected message.  If I try via DJI Assistant, it just stays as the USB screen, and never progresses to let me update.  I sent a message on FB on Monday and haven't gotten a response there, so I'm trying here.
Sir, may I know what's the current version of the DJI Assistant 2? And which step are you stuck with? And is there any error message when the update failed? It will be better to refer to 178# and export the upgrade log, I'll forward to our engineers for double check, thanks so much!
2018-9-10
C I N E R O G
Hey I wonder if we will be able to have two controllers attached somehow for a Camera Op panning the touch screen.
R
2018-9-10
umairaslam
Pakistan
Thats really amazing.
2018-9-11
fansbaa186d5
Flight distance : 3655085 ft
fans98d63e0a Posted at 2018-8-25 07:02
Does  anyone have a sample of the stitched panorama JPG that the Maverick 2 Zoom produces for download?  Even better would be the 8 or so [view_image] files too. Thanks!
Lightroom can do it, as can Autopano. They cost money but they offer quaility.
2018-9-12
Tomcatuk
Flight distance : 28743 ft
Oliver.Lauer@googlemail.com Posted at 2018-9-5 08:15
Cannot update the firmware.
I have tried to update the drone firmware via iPhone X and iPad Pro through the DJI Go 4 App as well as via a MacBook Pro and a Windows X Laptop through the DJI Assistant 2 for Mavic.
Sometimes the updating progress gets to 99% but most of the times it fails way before that.
That's why on the first line of the firmware announcement they write.... "we 'hope' that you can upgrade the firmware version...."
Mavic air all over again....
2018-9-12
Nico77
soccerace21 Posted at 2018-9-9 10:34
That's the one I was using - DJI Assistant 2 for Mavic...version 2.0.0.     Today, I uninstalled the program and downloaded the zip file instead of the exe and installed it that way, and it had no issue updating.  Not sure why the zip worked and the exe didn't, but whatever.
I had the same issue. It turned out my  Bitdefender had some serious issues with the app on the pc. Both from a “false positive” as from a “I need to be able to have access through the firewall” perspective.
After I fixed those issues everything worked fine.
2018-9-12
massipos
Here, i have removed previus version of the DJI assitant 2 first, and then have installed the new Mavic 2 version. After the M2Z activation, the firmare was succesfully uploaded and installed on AC and RC at first attempt whitout any issues, just follow video tutorial.
2018-9-13
Will_Bartlett
Update wouldn't work through my Mac with supplied USB cable, however I was able to successfully update the Mavic 2 to the latest firmware by using the DJI GO4 App on my iPhone 7. Did a test flight and a review here: youtu.be/orOpS5BbPl0
Subscribe if you guys like the video
Also, be sure to go into the camera settings and enable the 'raw' settings for panoramic (Save original), otherwise you're pano's might be saved overexposed and you won't be able to fix it.. I also found when tilting the camera in a waypoint hyperlapse, it caused some unwanted movement in the finished hyper lapse video.
Happy Mavic 2 flying everyone!
2018-9-13
BillTS
Flight distance : 434058 ft
why is not digital zooming available in photos?
2018-9-14
BillTS
but very nice anyway
2018-9-14
BillTS
2018-9-14
BillTS
network glitch, sorry
2018-9-14
BillTS
2018-9-14
BillTS
2018-9-14
BillTS
Admin plz delete my comment above plz
2018-9-14
mnix
Flight distance : 3865869 ft
I seem to have found a bug - accessing the sd card in the drone via the usb port doesn't work as it always gives access to the internal memory.  This is a pain if you want to do a quick playback on a tv.
When i plug in the usb cable from the mavic 2 pro to a tv (or computer) i can only access the internal memory. Even though dji go says the sd card can not be accessed because the usb is plugged in.
The sd card works fine in a computer, and the recorded video plays well.
If i select the internal memory in dji go, and plug in the usb, it says the internal memory is inaccessable because the usb is connected, so it seems it should be possible to do the same for the sd card.
2018-9-15
perline
Philippines
Glad it has been released! I hope to enjoy its features soon. This will surely help me with my security issues.
2018-9-15
OnosToolan
bjr981s Posted at 2018-8-25 00:14
Actually they do. When I ordered my Custom 981S from Zuffenhausen it was like most new Porsches updated by the dealer before delivery.
My Ducati bikes also required ECU updates at the dealer for the optional upgraded Exhaust systems before delivery.
I used to work in the motorbike trade and ECU updates were a very common thing on all modern bikes. We would update the ECU before a customer pick up and then on every service thereafter. So firmware updates if nothing new.
2018-9-16
damoUK
Flight distance : 693038 ft
Ok, please can this thread be killed? Every time I see it I get excited that there’s new firmware for the Mavic 2 and then realise it’s the same old one that’s just had a new comment added!
And now I’m guilty of adding a new comment and annoying everyone waiting just like me! :-)
2018-9-17
Ede45
damoUK Posted at 2018-9-17 14:49
Yes, me to
2018-9-18
DJI Susan
Buddy1976 Posted at 2018-9-8 05:30
hope this also helps my controllers on the latest firmware and the drone wont update. I wanna fly the bloody thing!
[14:10:27:688][DevMgr              ] DLL : DJIRadarService      ignore!
[14:10:51:316][DevMgr              ] Device Arrival : RNDIS_DJI_PHANTOM4_RNDIS&COM4
Hi there, just got an update from our engineers that they need more info, please kindly refer to the below and confirm:
1. Where did you get the drone?
2. What's the current version of the aircraft?
3. We need the data in the aircraft, please kindly refer to the below screenshot and export the flight data for analysis, thanks so much!
2018-9-18
DJI Susan
Olly_2.0 Posted at 2018-9-7 03:10
Hi Susan,
attached the current firmware statuses. [view_image]
Hi Oliver, could you refer to the 226# and export the flight data in the aircraft for further analysis? We need it to check the exact status and see whether the issue can be figured out remotely. Thank you!
2018-9-18
El Diablo
2018-9-19
Wibster
Flight distance : 11870 ft
I’ve tried applying the firmware, everything seems to have worked, on reboot and in the Assistant app when I go into the firmware area I keep getting a ‘Refresh’ option.  Does this mean the firmware update hasn’t completed correctly.  Apologies for the newbie question, but this my first drone and I want to ensure that I don’t go out with it, if there’s a potential problem
2018-9-19
zappy54
Flight distance : 482260 ft
Wibster Posted at 2018-9-19 02:12
The Firmware refresh is always there to give you the option to refresh at any time you have probs
2018-9-19
Wibster
zappy54 Posted at 2018-9-19 02:31
Brilliant, thanks for that confirmation, I wasn’t quite sure
2018-9-19
renedx
Flight distance : 31230 ft
Well.. just a heads up. We updated our Aircraft to the newest firmware. Third flight with that firmware, it dropped out of the clear sky... on a metal beam. (Case already taken with DJI)
Forum ppl who will request the flight log .. https://file.io/QTd77K
2018-9-19
eduwinner
Thank you for the information. I updated my mavic 2 but I can't activate it...
2018-9-20
Olly_2.0
DJI Susan Posted at 2018-9-18 04:53
Hi Susan,
I returned the drone as a DOA and got my new one.
Sadly not in time for my trip to Scotland, but today I gonna go out for the first flight with the new drone
2018-9-22
DJI Susan
Olly_2.0 Posted at 2018-9-22 01:13
Hi Susan,
It's nice to hear this. If there is anything else we can help, feel free to contact us.
2018-9-24
DJI Susan
renedx Posted at 2018-9-19 10:00
Hi renedx, sorry for the late response. May I have your case number? I'd like to check the current status and keep following up for you.
2018-9-24
DJI Susan
eduwinner Posted at 2018-9-20 16:11
Hi there, we've read your new post and responded as well: https://forum.dji.com/thread-167171-1-1.html
Please keep us updated there for better follow-up, thanks so much!
2018-9-24
renedx
DJI Susan Posted at 2018-9-24 19:06
Ofc you can. See PM. I hope we will have a replacement soon
2018-9-25
SamDownUnder
Flight distance : 112989 ft
C I N E R O G Posted at 2018-9-10 00:51
R
According to the manual (pg 47) that feature is coming.
2018-9-25
DJI Susan
renedx Posted at 2018-9-25 04:55
Well received, thank you! Upon checking the case log, the package has been shipped and the tracking number will be available soon, you may check the tracking status later.
2018-9-26
DJI Susan
R
Hi there, the dual-controller of Mavic 2 series will be available in the future. Our engineers are working on it and will release on our website as soon as it is ready. Thanks for your support and patience.
2018-9-26
Techwizard “Skip” Skipfx
Having real trouble getting Mavic pro 2 zoom to update firmware? Any ideas?
2018-9-26
rainslave
Flight distance : 243114 ft
Norway
Techwizard “Skip” Skipfx Posted at 2018-9-26 01:57
hook it up to your computer using Dji Assistant 2
2018-9-26
renedx
DJI Susan Posted at 2018-9-26 01:24
Received it (sadly without iOS connector cable... oops), but I'm checking with the NL office if it would be possible to pick one up at their office today. Thanks for the updates and the fast RMA replacement.
2018-9-27
