Mavic Air bricked by software
2132 16 2018-8-24
CharmlessNurk
Hello. I've had my Mavic Air since the end of April and it's been a joy. Up and down and round and round, taking pictures and video like some sort of art ponce.
Yesterday, I went to fly it, and it would not connect to the remote. No, nope, thanks but no. The function button on the drone just flashed yellow, no beep when pressed, no response. Just nothing. I'm using an iPhone 7 with the latest iOS. It won't connect via wired or wireless, RC or phone only. Won't let me access camera view. Nothing works. Not Go 4, not Assistant 2, not screaming at the sky and setting fire to a goat in supplication. Nothing.
I've tried updating the firmware via Assistant 2 but it fails every time. Every. Singe. Time. This is on an iMac running High Sierra 10.13.5 with a newly installed version of the Assistant software. The RC updated fine, but the drone just will not play ball. Assistant says current firmware version is 00.00.0000 which is nice. I have managed to reset to factory settings successfully, and then restarted the drone and tried updating the firmware. No joy.
What in the name of God's fragrant anus is going on here?
2018-8-24
DJI Natalia
Hi, we are really sorry about that. Can you please try to use different PC/laptop? Let's see if this will work. Thank you.
2018-8-24
CharmlessNurk
DJI Natalia Posted at 2018-8-24 16:48
Yeah just tried. Downloaded the Assistant app to my MacBook Air running High Sierra 10.13.5. Ran the update. Downloaded to 99% then stalled for 5 minutes before “failed” notice. Same as on iMac. Bored of this now.
2018-8-24
OneDoesNotSimply
Flight distance : 662644 ft
Try a proper computer and not that Mac nonsense ;)
2018-8-24
OneDoesNotSimply
Isn't there a factory or hard reset you can do on the Mavic instead of trying to update?
2018-8-24
LordoftheFlies
Following this thread...
2018-8-24
nixuspix
Flight distance : 2864974 ft
Latvia
Interesting what's going on?
2018-8-24
bjr981s
Flight distance : 139698 ft
When you reset back to factory did it then allow connection to the Assistant 2? The new Assistant 2 will be an issue. I had this same problem with my Spark when the Air was released and updated the Assistant for the Air. It bricked my Spark next fly safe database update and DJI replaced it for Free and Free shipping.
2018-8-24
CharmlessNurk
bjr981s Posted at 2018-8-24 23:00
I didn't have any issue connecting to Assistant 2. It was already on my iMac and I downloaded it to my Macbook at the suggestion of the mod/admin on here. On both machines it connects just fine, recognises the drone as a Mavic Air and downloads 99% of the update before "failure". I connected the Mavic RC (eventually worked out you have to connect by the micro USB port on the side rather than the main USB port underneath), and updated the firmware on that just peachy. But the drone will not update no matter how many times I swear at it.
2018-8-25
bjr981s
hmmm. now that you have updated the controller try using the iPhone to do the update. Completely uninstall DJI Go 4 off the phone first and reboot make sure that the Go 4 data has been deleted then try again.
I can only think that you have a corrupted FW file.
Cheers
2018-8-26
CharmlessNurk
bjr981s Posted at 2018-8-26 08:57
Thanks. I've tried this. No joy. The phone simply does not see the drone.
2018-8-26
bjr981s
CharmlessNurk Posted at 2018-8-26 11:51
I guess you will need to send it off to DJI.
2018-8-27
CharmlessNurk
bjr981s Posted at 2018-8-27 04:41
Yep, looks that way. Tra la la, what a joy.
2018-8-27
djiuser_KXGKENc145UO
Flight distance : 8219 ft
Mine is flashing green red yellow and can't connect the drone to anything only the rc will connect to the app and assistant 2 what can I do
2020-5-7
Monk32
Flight distance : 50915 ft
Greece
Hi..before send it to service, try a connection without the sd card in drone's slot.
A corrupted sd card can disrupt the drone operation completely.
2020-5-11
There is no sd card in the drone at all
2020-5-11
fansbc0f1fc8
Martinique
I have done the same thing with my MP2 I think
2020-6-12
