Daninho
Flight distance : 70203 ft
It has nothing to do with props, the jello effect is caused by gimbal vibrations. Some P3 gimbals will vibrate when the p3 is powered on or at certain angles, some more, some less amd some are perfect. This vibrating is visible as a jello effect in the recorded footage. Im not sure why that happens but it could be the case that the standard PID data DJI is using will not fit for every gimbal because every motor is anit different but we can only speculate. Interesting here is that mine said MC error and another Jello phantom said the same. And it said gimbal IMu error, rebooting once. Maybe this is just a software thing and you need custom PIDs for your gimbal. |
