Terrible Video Lag...
1082 7 2018-8-29
ocelot27
Flight distance : 1163894 ft
Hey,
Just set up the M2P yesterday and encountered some pretty severe video lag - in both 720 and 1080p - basically made the drone unflyable as the video feed was several seconds behind the actual drone. The drone responds to stick commmands normally - so this is just a video issue.  Occurs during regular flying and during recording video.
Any Ideas - all FW UTD - Using iPad Pro 9.7, video feed transmission set to auto in the radio.
-john
2018-8-29
DJI Paladin
Flight distance : 318 ft
Hi there, sorry for the inconvenience. Can you please provide a short video showing the issue so that I can check it on my end? You can upload it by using  google-drive or Dropbox and provide the link here. Are you also having an issue on the files from the SD card?
2018-8-29
hallmark007
Flight distance : 9827923 ft
You might try changing cable, if nothing it will eliminate that.
2018-8-29
ocelot27
DJI Paladin Posted at 2018-8-29 06:20
No the saved footage is normal - it's acting like a video link issue - will try to get some video of it later today - how do you record the screen on an iPad again?
2018-8-29
Suren
Flight distance : 13425892 ft
South Africa
ocelot27 Posted at 2018-8-29 06:35
the apple range has a screen recorder when you swipe upwards menu
2018-8-29
DJI Paladin
I'm sure our co-pilots here can give you a best recommendation on how to do it on your iPad. It is also better if you asked for help from an Apple support to make it easier. Thanks for your understanding.
2018-8-29
ocelot27
So it was a bad card - sorry for the alarm - swapped out for a different card and all is good so far...
2018-9-4
DJI Paladin
ocelot27 Posted at 2018-9-4 08:12
That's good to hear. Let me know if you have another concern, thanks!
2018-9-4
