Only 200 meters!
1210 7 2018-8-31
youngwac
hello! since a week or two my mavic air loses connection after almost 200 meters. usually it flies at least 2km so what could be the issue here? Thank you!
2018-8-31
saviour
Flight distance : 604203 ft
You should provide more information.
CE or FCC? 2.4 GHz oder 5.8 GHz? What surroundings? Same place as weeks before? Did you update the App to the newest version? (Newest update seems unstable and unreliable)
2018-8-31
Mark_One
Flight distance : 112123 ft
South Africa
Had similar issues with the latest update, went back to an older version problem solved hopefully it's as simple for you as well.
2018-8-31
Alex Batalov
Flight distance : 21105262 ft
I recommend do the downgrade to the previous version on which you were achieving 2km.
Safe flying.
Alex.
2018-8-31
DJI Paladin
Flight distance : 318 ft
Sorry for the trouble. Did the issue started after firmware upgrade? May I know what is your current firmware version? Did you receive an error message on the APP? If yes, kindly provide a screenshot of the error message. Are you flying near in a restricted area like airport or military base? You can check the video tutorial below on how to properly position your antennas. Thanks for your support.
2018-8-31
NedUK
Flight distance : 555262 ft
Defiantly the stock remote to phone cable, change it for one from amazon of decent quality.....
2018-8-31
NedUK
2018-8-31
Bluehook
Flight distance : 790814 ft
@NedUK> Link?
2018-8-31
