Battery firmware mismatch
1823 13 2018-9-10
jimmylee
Flight distance : 367352 ft
I received a new battery for the Mavic 2 several days ago and have
made about 10 flights with this battery without a problem.
I decided to run the DGI assistant to see if any new firmware was available
and it told me there was a mismatch that the new battery had to be upgraded with new firmware.
I thought DJI4 App is suppose to warn you when a firmware is available even for the batteries.
In this case it did not but there was no issues flying with the mismatched firmware.
2018-9-10
Wachtberger
Flight distance : 261509 ft
I have never seen a firmware update only for the batteries. But after a firmware update of the aircraft as it has been the case for the Mavic 2 right after release, you always have to check with at least one additional battery if they are concerned as well and then repeat the update with them. DJI Assistant is the best tool to check this.
But you are right that DJI GO 4 should also have warned you about the mismatch.
2018-9-10
JoeMavicDHH
Flight distance : 8230085 ft
Wachtberger Posted at 2018-9-10 11:58
Hi Andreas, in this case you're wrong. If you update the drone, the battery update - if necessary - comes with it. If you shut down only the Mavic, change the battery (i.e. from the Fly More Kit) and reboot, DJI GO 4 comes up with a firmware mismatch message (for "other components") and you can slide for upgrading. The flashing of the battery power indicator shows that actually the battery firmware is updating. At least it happened this way with my batteries #2 and #3.
2018-9-10
DJI Stephen
Hi there, thank you for reaching out and we're very sorry for the Inconvenience. Regarding with that if you have multiple batteries then you update the Aircraft, Once the Aircraft is updated you need to insert each battery to the Aircraft for the battery to be updated. And about the Mismatched concern most likely it will prompt you from the App saying you have a mismatched firmware and make sure as well you updated the Remote.
2018-9-10
Wachtberger
JoeMavicDHH Posted at 2018-9-10 13:00
But this is exactly what I tried to explain. Both DJI GO 4 and DJI Assistant should come up with the firmware mismatch message and update the battery. Just in above case it has been reported differently.
2018-9-10
JoeMavicDHH
Wachtberger Posted at 2018-9-10 13:08
...I just referred to your first sentence.
2018-9-10
Wachtberger
JoeMavicDHH Posted at 2018-9-10 13:11
The first sentence is correct as well, or have you ever seen a firmware update for the batteries only? From my experience so far they always come together with a firmware update for the aircraft while the batteries are not always affected too. Nevertheless we always have to check to be on the safe side.
2018-9-10
JoeMavicDHH
Wachtberger Posted at 2018-9-10 13:15
Sorry if I hurt your feelings regarding your expertise. I didn't intend to start an argument.
2018-9-10
Wachtberger
JoeMavicDHH Posted at 2018-9-10 13:19
You did not hurt any of my feelings at all and I am always happy to be corrected by others who know better! So please tell me what was wrong in my statement? I happily learn from your experience, honestly.
2018-9-10
JoeMavicDHH
Wachtberger Posted at 2018-9-10 13:22
...all good. No more useful information available!
2018-9-10
parkgt214
Flight distance : 1167008 ft
How does one know whether the batteries included with the Fly More need to be updated?   I have flown all three multiple times with no message.
2018-9-10
jimmylee
parkgt214 Posted at 2018-9-10 14:53
That's what I was saying.
The DJI Go 4 App does not warn you they need firmware upgrading.
You have to run DJI Assistant to upgrade them.
2018-9-10
Aeromirage
Flight distance : 1778045 ft
I upgraded the firmware on my M2P and then put my other 2 batteries in. No message stating they needed upgrading. (Through DJI assistant)
Then went out to fly and got Firmware mismatch message which then took at least 5 minutes to complete. (In the field)
When I got back home, I again connected bird to computer and put in all 3 batteries, restarting everything each time. No changes.
Went out to fly the next day and got the mismatch thingy again with 5 minute update in the field.
What is going on here? Does the app not see anything unless out in the field away from wifi?
This is getting aggravating.
2018-9-10
jimmylee
Aeromirage Posted at 2018-9-10 16:58
Very strange behavior. maybe try refreshing the firmware using assistant.
2018-9-10
