Red light on a remote controler
759 15 2018-9-12
smirnoff9969
Flight distance : 582776 ft
Croatia
Hello,
I got red light on my remote jest beside power switch. what does this mean?
and sometimes remote can not connect to my DJI app on my phone. app is woking but there is o camera feed from my drone. link between remote and drone is OK, since I can ajust tilt of the camera up/down
smaller green LED for batery status are 2 or 3 `on`  so I guess battery is charged OK for flight.
can somebody explain?
2018-9-12
ALABAMA
Flight distance : 10442687 ft
Have you updated the firmware, or crashed lately?
2018-9-12
Peterx
Flight distance : 1499708 ft
Connection from the RC to AC failed. Relink that parts together.
2018-9-12
smirnoff9969
Croatia
no crashes ever!!!
no I did not update to 1.9 FW (I think its 1.9 version now ) because my internet ADSL provider have underground cable burned, due to thunder this summer, and nobody konws when it will be repaired...so I don`t have acces to update.
but last sunday I made some autumn videos of nearby landscape  and flight went OK.  (can`t post video cause of technical issues).
2018-9-12
smirnoff9969
Croatia
peterX - what does this means?
2018-9-12
Peterx
Controller-or/and WIFI signal not available from the AC to the RC and in return.
2018-9-12
DJI Natalia
Hi, sorry for the trouble caused. Just want to clarify, may I know what's the model of your Phantom? Can you please re-link your remote controller to your aircraft?
2018-9-12
smirnoff9969
Croatia
I have 3 standard edition.
when I turn on craft, remote and phone (with app DJI GO) I dont have camera feed on my mobile. app is working normaly, camera wheel on remote work normaly just dont have video.
2018-9-13
WD9EON
Flight distance : 686886 ft
smirnoff9969 Posted at 2018-9-13 04:58
Have you connected to the Phantom's wifi before starting the DjiGo?  It's a must do.
2018-9-13
Peterx
Do you get telemetry ? If not then you did not connect you phone/tab to the birds WIFI.
2018-9-14
smirnoff9969
Croatia
WD9EON - well I don`t recall sequence of powering up ...usaly remote first, then aircraft then app...really don`t remember...
peterx - on wi-fi options I get message "conented to phantom 3..." but I noticed, button "camera" on DJI app id gray - no video feed... but if i`s blue, then I get videofeed after pressing...
2018-9-15
Peterx
If the cam button on the Go app grayed out and not solid blue then the phone is not correctly connected to the P3S system. Do you have Bluetooth enabled too? if yes then disable it....and enable the airplane mode too and see what happens.
2018-9-16
smirnoff9969
Croatia
Peterx Posted at 2018-9-16 00:57
ok I`ll try that.... (can`t wait my IT provider to repair those underground cables so I can be faster in reply)
2018-9-18
Peterx
Before i forget to say,i say it now . If you enable the airplane mode you may start WIFI on your phone manually.
2018-9-18
smirnoff9969
Croatia
Peterx Posted at 2018-9-18 09:26
that`s OK I know that
2018-9-19
Droner500
I had a problem just like this once. I think you need to link the rc. Here is a video on it:
2018-9-19
