USB unit need to be analyzed and corrected
612 6 2018-9-12
massipos
It happens at every time: when I connect the drone, I get warned by windows that the usb drive needs to be analyzed and corrected.
The same thing happens with my little Spark. I let it go and I do not analyze and no correct anything, and everything has always worked
correctly. I opened this discussion to find out if it will happen to you and how you do.
2018-9-12
Blellow
Flight distance : 1311056 ft
I get it too.  When I take the card out and connect it to the PC.  Just something to live with.
2018-9-12
massipos
I don't remove the sd card usually, but connect AC with usb cable to PC and download pctures and movies, at this time get the alert. Sure, i don't want my PC, format, or do some like that, at the SD or other drone's memory card they are inside the AC.  So i don't care about that and make my operations.
2018-9-13
DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize for the troubles. I'd like to know if you already switch and use a different cable? Also, what is the firmware version of your aircraft? We're here to help you. Thank you.
2018-9-13
massipos
DJI Gamora Posted at 2018-9-13 03:59
Tanks for try to help me.
My Sparky's firmware is the old version 01.00.0700 and my M2Z wersion is the last 01.00.00.00.
I for each AC use the stock cable to connect to my Windows PC
2018-9-13
DJI Gamora
massipos Posted at 2018-9-13 07:35
Hi, thanks for your fast response. You might need to use another computer for you to update the firmware of your aircraft for your Spark. I would like to confirm what is the Mavic series you own?
2018-9-13
massipos
DJI Gamora Posted at 2018-9-13 08:33
in relation to the Spark, I have already tried to change pc, with the same result. However I do not intend to update the firmware: the problems that many complain, can not be compared with a warning that i can not consider. My the Sparky that now flies perfectly with OTG and more.
About the M2Z serial is some like OM6DF7T*******
Thanks for the interest
2018-9-13
