CinemaDNG Raw Inspire 2 recording problems Log
2288 7 2018-9-24
fansb35e09e6
Flight distance : 19232 ft
Had an important commercial shoot Sept 22, documentary Netflix.  CinemaDNG was there but the choice for DLOG (flat image) was gone in 6K...only choice was Raw.  How can this happen?  Result was footage looked like REC709 !
2018-9-24
DJI Tony
Hi, Sorry for the inconvenience that it caused. What mobile device are you using? Is it occurring the all the time? Would it be possible if you can provide a screenshot of this? Please keep us posted. Thank you for the support.
2018-9-24
fansb35e09e6
DJI Tony Posted at 2018-9-24 16:57
2018-9-24
TheMightyThor
Flight distance : 2224665 ft
From my understanding, RAW is RAW. There is no log profile you can shoot on the X7 in RAW. Log is only available in H.264/5 and ProRes.
2018-9-25
Airking Pilot
Flight distance : 3228383 ft
Argentina
"footage looked like REC709" is wrong if you recorded RAW. May be the SD received a "REC709" H264 image, but in your SSD you have the CINEMA DNG image with plenty of room for postproduction. The only time you need D-Log in your SSD is when you´re recording PRORES
2018-9-25
PH2DW
Flight distance : 39537 ft
Just checked my footage in Raw with current firmware vs raw shot on 14-04-2018. The looks are similar. So think you're good.
2018-9-25
Barry Goyette
Flight distance : 14928 ft
Raw IS raw. However raw "profiles" can differ, and be applied differently across various color/editing programs. The previous Log look for C-DNG was one such profile, and you must see it as not how the Raw file is encoded, but rather, a Metadata set of instructions for how the raw converter should see the file. (it has no impact on the actual data stored in the Raw file). I believe DJI has gone, with the introduction of apple ProRes Raw, to a system that allows you to convert  the Raw image to D-Log in your coloring program. This apples to C-DNG as well. If you go to the download page for the x7, you'll see a raw to d-log conversion LUT, along with a d.log to rec.709 LUT. These can be used in combination in Resolve. Not sure if Premier will let you apply it as well.
2018-9-27
fansb35e09e6
Barry Goyette Posted at 2018-9-27 08:42
Excellent explanation.  Thank you so much!
2018-10-2
