Spotlight mode of Mavic Air behaves strange.
1338 10 2018-10-2
Tonsuke
Flight distance : 609377 ft
My Air behaves strange with Spotlight mode of active track.  It reacts stick movement but doesn't move as I operate.  Sometimes right becomes left, forward becomes right, and sometimes backward becomes forward left becomes backward.  It's totally unpredictable.  Does anyone have same experience ?
2018-10-2
DJI Paladin
Flight distance : 318 ft
I'm really sorry to hear that. Did you receive an error message? If yes, kindly provide a screenshot. Please make sure that the remote controller is calibrated. You can restore the settings to factory defaults and update the firmware using DJI Assistant 2. You can download the software here: https://www.dji.com/mavic-air/info#downloads and follow the video tutorial below.
2018-10-2
Tonsuke
DJI Paladin Posted at 2018-10-2 01:15
https://www.youtube.com/watch?v=XPmWvxeSp7E
I didn't get any error message at all.  Anyway, I'll try reproduce this tomorrow and will have screen recorded.  I assume that the calibration of controller is not a cause of the issue hence it occurs only in spotlight mode of active track.
2018-10-2
Tonsuke
One very basic question, we should be able to move and control the quad even in spotlight mode, right ?  The reason I'm asking is someone told me that spotlight mode is just tracing object with only automatic yaw and gimbal pitch movement with making quad at stationary position.
2018-10-2
DJI Paladin
Tonsuke Posted at 2018-10-2 03:26
Kindly refer on the attachment below.
2018-10-2
Tonsuke
DJI Paladin Posted at 2018-10-2 03:44
[view_image]
Thanks, confirmed.
2018-10-2
DJI Paladin
You're welcome.
2018-10-2
Tonsuke
Here you go.  I tested and recorded my P4P as well to have a comparison.  As you can see, Air reacts very, very strange way and it is totally different from the behavior of my P4P.
2018-10-3
Tonsuke
Seems direction has been fixed when you started active track and absolute direction becomes a base of interpretation of stick movement.  Then left becomes right, forward becomes backward depends on relative direction of the aircraft.  This is useless.  Spotlight mode on other aircraft like P4P is very useful and I love that.  Please, Please fix this issue....
2018-10-3
Amjad1983
Flight distance : 310489 ft
Luxembourg
i had same issue with my MA also  , but i am not  concerned  to complain about it because i am not using spot light frquently
2018-10-3
Tonsuke
Would you give any thought about the video I uploaded ?
2018-10-4
