fans600cb799
Flight distance : 1032933 ft
DJI Thor Posted at 2018-10-2 19:43
Hi, I am sorry for your loss, that must be frustrated for you. However, we are terribly sorry to tell that if the drone is out of warranty, we may not be able to provide the data analysis service, no data analysis, we are not able to tell you the reason of this accident.
In your case, if it is convenient, you can provide me with your contact info and the ticket number, I will forward your case to a higher department to assist.
Besides, have you tried to find your drone via the Find My Drone function? If the drone can be retrieved and you can get the data from the drone, you can also refer to this tutorial and try to locate the issue of the accident. Thank you for your attention.
Thank you for the reply
I understand the drone is out of warranty but as far as I can tell this was not down to pilot error and I am not confident in flying my Mavic 2 pro.
Without any support from DJI and losing a drone through no fault of my own, leaves me in a difficult position.
I did use the find my drone aid and spend hours at the area, even contacting local restaurants to check security cameras out side on the street.
As my flight log shows the drone disconnected at 250 feet without warning.
My number is #1390045
Kind regards |
