Spark will not connect to Remote
1481 17 2018-10-7
marka2k65
Flight distance : 594131 ft
Lost connection to the remote, tried relinking no go. Tried the tutorial to reset the WiFi (after power up hold the power button for nine seconds wait for three beeps power off and try to relink no go, did this for both the Spark and Remote) I can connect to the Spark using the iPhone and WiFi, but cannot see the WiFi for the remote also when I try to scan the code on the remote the camera is black and will not scan at all. Did a Firmware upgrade from the PC for the Spark to the latest version and reset back to default same issue. Any assistance is appreciated.
Mark
2018-10-7
S-e-ven
Flight distance : 5922034 ft
Thailand
Start the RC and the Spark, wait till "on",  push on Spark power-button for 3 seconds, till ONE beep
Push on RC the 3 buttons till beeping
keep close to Spark, beeping stops,  paired ;-)
2018-10-7
S-e-ven
Thailand
oops, forgot:
2018-10-7
marka2k65
Appreciate the reply and video but my remote will not beep continuously, it just beeps once I have waited upward of 45 secs holding the pause, FN and customization button, I have also been close to the Spark while performing this.
2018-10-7
ssylca44
Flight distance : 434721 ft
Hi,
Just a thought, should you check if the RC has the latest firmware?
Cheers.
2018-10-7
marka2k65
ssylca44 Posted at 2018-10-7 12:25
Hi,
Cheers.
I have no connection with either my iPhone or Note 8 to the remote control, I can connect to the Spark though so I am unsure how to check the firmware to the RC. The RC blinks red three times then pauses and starts over.
2018-10-7
S-e-ven
Get a cable and check if you can get a connect in the Go 4 app.
If not: contact service
2018-10-7
ssylca44
That would have to be an OTG cable to connect to DJI GO4, either with an iPhone or Tablet. Is the RC SSID broadcasting?
2018-10-7
marka2k65
ssylca44 Posted at 2018-10-7 14:00
No the RC is not broadcasting an SSID only the Spark does.
2018-10-7
Wolferl
Flight distance : 23793 ft
Austria
marka2k65 Posted at 2018-10-7 14:23
Can it be that your R/C is transmitting the Wifi on 5.8 GHz and your phone is not capable of that?
Just a wild guess...
Cheers,
Wolferl
2018-10-8
marka2k65
Wolferl Posted at 2018-10-8 00:20
I loaded a WiFi Analyzer on my Note 8, it sees my home Wireless on both 2.4 and 5GHZ but not the RC, I am thinking the RC is bad Probably time to contact service I appreciate all the replies
2018-10-8
Wolferl
Austria
marka2k65 Posted at 2018-10-8 02:45
Ah ok, well than you can try to do a factory reset of the R/C. If that doesn't help, open a case with DJI.
Cheers,
Wolferl
2018-10-8
DJI Wanda
Hi there, thanks for reaching DJI Forums. Can you please verify when did you purchased your spark remote controller, if it still under warranty (12 months) I highly suggest to send it for repair. https://repair.dji.com/repair/index Thanks!
2018-10-8
marka2k65
Wanda
I will need to confirm but I believe it was purchased September 2017 through the DJI online store. I will go ahead and contact service and see what can be done. Mark
2018-10-8
S-e-ven
Thailand
in which band is the birds wifi?
Is the wifi analyzer covering the 5.8 Ghz?
2018-10-8
DJI Paladin
Flight distance : 318 ft
marka2k65 Posted at 2018-10-8 06:12
Wanda
Hi there, thanks for your response. You can provide your serial number to me via PM so that I can check the warranty of your product. Please keep us posted, thanks!
2018-10-14
fans95359f7f
Ukraine
1. Turn off Controller and Spark
2. Turn on Controller
3. Reset Controller (long press for 9 second Power Button)
4. Turn Off Controller
5. Turn On Spark
6. Long press on Battery button for two beeps (6 second)
7. Turn off Spark
8. Turn On Spark
9. Long press on Battery button for three beeps (9 second)
10. Turn Off Spark
11. Turn On Spark
12. Once Again press on Battery button for two beeps (6 second)
11. Then (without turn off) press on Buttery button for 1 beep (3 ceconf)
12. Turn on controller
13. Press tre battons Red Pause + Fn + Right Custom button till you hear short beeps and green sparking light
14. They connected in my case!
Had the same issue with spark. What worked for me after talking to DJI support: when you reset spark's wifi settings with 3 beeps (holding power for ~9 seconds) turn it off immediately once you start seeing spark LEDs blinking green! Don't wait and just turn it off once it starts blinking green. Then, when you turn it on again, give it a few seconds to warm up and start, and hold power for 3 seconds. After that controller pairs to drone no prob in a standard way (3 buttons pressed at the same time). works like a charm.
2019-2-13
Joller79 DK
Flight distance : 26447 ft
Denmark
Could be a brickes rc... Thought dji was over that.. There were quite some cases last year...
And that is why i dont update my rc and spark anymore
2019-2-14
