P3P Should I upgrade or leave it alone ?
2140 27 2018-10-11
Air/America
"App" is currently 3.1.43
"Version" is currently 1.5.30
"R.C." is currently 1.9.3
2018-10-11
w1r3ds
I would leave it be, mine has been out of date for over a year and it still fly's without any problems
2018-10-11
RedHotPoker
Flight distance : 165105 ft
Updates happen, glitches are fixed, new features are sometimes introduced, better camera options.
Updates are seriously worth the effort.
I have done every Firmware Update, since the Phantom 3 was released, and never experienced one single issue.
I only regret iOS version lost the Battery Life segment.
RedHotPoker
2018-10-11
sky wombat
Flight distance : 1454078 ft
Thanks for the reminder, I have to put mine back together & haven't got this far yet.
2018-10-11
RedHotPoker
sky wombat Posted at 2018-10-11 23:23
What was it taken down for?
Yes, you need to get it up, again. ;-)
RedHotPoker
2018-10-11
sky wombat
RedHotPoker Posted at 2018-10-11 23:27
a tree moved in front of it quite some time ago. I bought the P3A & P4P while I repaired it
2018-10-12
Phantom One
Flight distance : 135299 ft
If it fly's without issue, Leave it!
2018-10-12
RicardoGray
Flight distance : 4356421 ft
sky wombat Posted at 2018-10-12 00:40
I know a lot of users are fearful of upgrading, and rightfully so. But I am like RHP, I have always stayed with the latest stuff and haven't had any issues. Not to say that it can't happen though. But if you are familiar with the procedure, and understand what is going on, and what to do if somethings goes wrong, you should be fine. I have had multiple phantoms and helped friends as well with upgrading. Make sure you have a full battery, and let the process finish completely. Know what to look for when the process is done, so you don't power it off before it's done.
Now, talking out of both sides of my mouth here...……….if your phantom is flying ok, there probably isn't much to gain by upgrading. Maybe a few bugfixes and of course updating those pesky NFZ databases, and of course no more getting that message!
It is truly a mixed opinion and one you will have to make for yourself. Good luck either way.
2018-10-12
ALABAMA
Flight distance : 10442687 ft
It's just a gamble.  Have updated times with no issues and once where it bricked everything.
2018-10-12
RedHotPoker
ALABAMA Posted at 2018-10-12 05:49
I like throwing bricks, in the heat of the moment. Haha
RedHotPoker
2018-10-12
RedHotPoker
RicardoGray Posted at 2018-10-12 05:40
I beleve the small percent of all drones affected negatively by updates is minuscule, in comparison to the vast numbers that are sold.
RedHotPoker
2018-10-12
DJI Wanda
Hi, thank you for reaching DJI Forum. We suggest to update the version of your P3P to updated version v1.11.20. If you have any concern please let us know. Thank you for your support.
2018-10-13
Air/America
Thanks for everyone's opinion, suggestion and reply. I have upgraded. Now, no longer seeing the "update firmware" message at top when starting the Go App. Seems to work ok inside the living room. I will have to take the contraption outdoors and try it.
"Version" is currently 1.11.20
2018-10-13
RedHotPoker
Air/America Posted at 2018-10-13 12:12
Please let us know, the outcome once you fly.
Thanks for asking about updates...
Have a safe flight.
RedHotPoker
2018-10-13
A CW
Flight distance : 13926112 ft
I always update FW (on IOS)
2018-10-14
Markmark
I have updated and now RC Signal is lost
2018-10-14
Cobraman
Never update if you can avoid it ... this is a lesson learned the hard way when I got my first DJI. You don't need it. Any additions, if yours is running OK, aren't worth the risk. Leave it alone and just fly it.
2018-10-14
Phantom One
I wouldn't update either, hope the poster doesn't have any issues.
2018-10-14
RedHotPoker
Markmark Posted at 2018-10-14 07:52
Rebind it. Nothing to it.
Relinking the aircraft and controller is a simple task.
RedHotPoker
2018-10-14
RedHotPoker
Cobraman Posted at 2018-10-14 09:01
He had already done so.
With no problems to report.
RedHotPoker
2018-10-14
RedHotPoker
Phantom One Posted at 2018-10-14 10:34
It’s a minor gamble, but very few encounter difficulties.
RedHotPoker
2018-10-14
Phantom One
Yes, I see that.
2018-10-14
Phantom One
and it's not that I'm worried about issues during install, it's the restrictions they keep adding.
2018-10-14
Mark The Droner
Flight distance : 2917 ft
Here is a fascinating post I just ran across this morning in the other forum regarding the analysis of signal attenuation on a P3P.  I don't believe this kind of detailed analysis has ever been done on a DJI device  before.  This compares signal attenuation variances between AC FW versions starting with 1.05 (1.5).  Note that this analysis is only done regarding the boards in the AC and has nothing to do directly with the RC.  The member hasn't done an analysis of the RC (yet?).  If I am understanding this correctly, this chart below is showing the deliberate attenuation (weakening) of the incoming signal being received from the RC to the AC.  The incoming signal from the RC is received by the AC and then weakened before being sent to the receiver.  This, of course, would result in perceived signal loss and early fail-safe.  What is attenuation?  It's the deliberate weakening of a signal at the receiving end- usually done to solve the problem of a transmission which is too strong for a receiver - usually because it's too close to a transmitter.
Interestingly, it appears the attenuation changes mostly targets those in CE mode.  FCC mode is mostly unscathed and even seems to benefit slightly from the upgrade depending on the board/channel.  The analysis shows that there are only attenuation changes when moving from AC FW versions 1.07 (1.7) and below to AC FW versions 1.08 (1.8) and above.  Also, it appears there is no attenuation differences in the AC between FCC and CE modes prior to FW 1.8, but remember, the signal strength was likely diluted from the controller in CE mode, so you likely still wouldn't enjoy full FCC mode distance if you had an older AC FW version in CE mode.  But it would help.
Obviously, this data has negative FW upgrade implications to all DJI devices - not just to the P3P.
https://phantompilots.com/thread ... 39237/#post-1400396
To topic, should you upgrade?  I still like Oso's advice from the other forum.  Let everybody else upgrade first.  Wait a bit and read the forums and look for possible upgrade problems.  Make the decision based on the info you gather in the following weeks.
Good luck
credit:  quaddamage at phantompilots
2018-10-19
Mark The Droner
Here's some good info re FW upgrading your P3A/P:  https://phantompilots.com/thread ... .87175/#post-901549
Air/America - note that Oso recommends moving up from FW 1.5.  IIRC, there is a risk of the battery shutting itself off mid flight when the battery is not above a certain temperature.  Moving up from 1.5 will solve that problem.  Or you could just make extra double sure your battery is nice and toasty, preferably at least 25C, before any flight.  Good luck.
2018-10-19
Air/America
Thanks for the replies and suggestions. The drone is currently set as;
Looks like it is working well in the living room. I will have to take it outdoors soon if some good weather ever shows up.
2018-10-19
Air/America
"App" is currently 3.1.46
Also, I have three batteries,
two batteries on the DJI-GO Aircraft Battery/Advanced Settings/Details Page reports as "Current Status"  "Connection OK"
one battery on the DJI-GO
Aircraft Battery/Advanced Settings/Details Page reports as "Current Status"  "Self-discharge in storage"
What is wrong with that and what could be the problem? All three are DJI OEM batteries.
2018-11-6
Air/America
The current version numbers seem to perform Ok and the batteries all seem to report simarily.
2018-11-17
