Why does my video look awful?
1253 14 2018-10-15
woland
Flight distance : 60240 ft
Hi
I shot this on my M2P using D-LOG M and the DJI LUT. I shot at 4K HQ 25fps f/2.8 1/50 ISO 100:
I used cinematic mode and very steady control movements. I imported the file from the SD card to FCPX, applied the LUT then exported the master file, manually uploading to YouTube.
The video still looks terrible though? Any suggestions? I've watched so many tutorials and thought I had absorbed everything but I'm still really unhappy with how this looks
2018-10-15
DJI Gamora
Hi Woland, I think decent enough in my opinion. The only thing caught my attention was the latter part of the video. But you did a good job overall. Thank you for sharing. Have a safe flight always.
2018-10-15
Zatx
Flight distance : 158166 ft
The Dji LUT makes everything look very orange and you'll need to adjust color settings yourself. Other than the color grade, what is it you think looks bad?
2018-10-15
woland
Zatx Posted at 2018-10-15 04:39
Hard to describe - the focus feels very soft? I ensured it was set at infinity but it doesn't look great IMHO.
Besides adding some manual adjustments - can you see any other areas I should focus on improving?
Thanks for the feedback
2018-10-15
El Diablo
2018-10-15
woland
El Diablo Posted at 2018-10-15 05:17
Fly backwards.
Seriously, if you are going to end your video in a specific focus point, fly backwards and reverse the footage in post, it will look smoother and natural, no jerky adjustments.
Exactly what I was looking for - thank you El Diablo. I neglected to mention this was already reversed. I shall try the post processing tweaks and see if I can salvage this clip. Otherwise I shall try your other suggestions next flight - thanks again
2018-10-15
El Diablo
2018-10-15
MagicRide
Flight distance : 6766027 ft
woland Posted at 2018-10-15 04:41
I had the same problem but the way to change that orange look is to play with the WB. I now shoot no higher than 5400 kelvin. If you use sunny or cloudy the picture will be very warm and give you that fuzzy orange look. Also raise your sharpness to +1. It takes awhile but once you've got your numbers dialed in you will get a beautiful sharp, color balanced picture. However I still think your picture quality is pretty good.
2018-10-15
woland
MagicRide Posted at 2018-10-15 07:05
Thank you MagicRide - pretty sure I set this to Sunny which corroborates your findings. I'll be sure to try 5400 next time. I'm hoping adjusting the sharpness in post can save this footage :-)
Thanks again
2018-10-15
A CW
Flight distance : 13926112 ft
Enhance the definition in post a little but overall I think it looks good.
2018-10-15
M Stuart K
Flight distance : 1267717 ft
Looks out of focus to me.
2018-10-15
Squashpile
Flight distance : 214019 ft
Something looks off to me too. Focus or noise. I'll check it again on a 4k monitor later, but that does not look good.
2018-10-15
M2Wair
Flight distance : 1192231 ft
Looks out of focus on my 4k monitor. Did you use AFC or MF!
Try following this video for perfect fixed focus with the MP2
2018-10-15
woland
Hi
I used MF set to infinity - not sure what I did wrong with that - will have a look at the video.
I have tried adjusting the sharpness, white balance, and contrast and here's the result - still feels wrong though
2018-10-15
woland
M2Wair Posted at 2018-10-15 10:57
I suspect I didn't reduce a stop away from infinity as shown in this video. I should have checked focus peaking better but I'll know for next time
2018-10-15
