Pano with direct sun
1707 18 2018-11-2
vasi
Flight distance : 16099 ft
Hungary
Hi,
is there any solution for making panos with direct sun in front of the spark?
See this example, the result is a big white spot around the sun.
I am no PS expert so would prefer some kind of setting on the spark which helps, but if there is a solution in Lightroom that is welcomed as well
Thanks!
2018-11-2
vasi
Hungary
Thanks Lake Bled and Bohinj, Slovenia. The weather was just too good for the perfect pano shot
2018-11-2
spookster
Flight distance : 419649 ft
unfortunately there is no easy way of fixing this.
you could adjust camera setting while facing directly to the sun to avoid the huge white blob - lock the settings and do your panorama then.
of course you will have a way darker image overall but you can try to hit a sweetspot so you have smaller sun glare and nice detail.
that kind of panorama can be adjusted easier in lightroom.
in photoshop you could probably get away with some brush-/featherwork reducing the size of the glare, but it is difficult to get "natural looking" result (especially with the huge reflection on the water).
2018-11-2
A CW
Flight distance : 13978875 ft
Beautiful shot
2018-11-2
S-e-ven
Flight distance : 5922034 ft
Thailand
Try to do the Pano/Sphere twice, one with "the right" setting for the sky, one with the right setting for the sun
Mix the two Panos and hope it works
2018-11-2
vasi
Hungary
S-e-ven Posted at 11-2 03:37
This could work, good idea! Thanks!
2018-11-2
vasi
Hungary
spookster Posted at 11-2 03:25
Thanks for the suggestion! I will experiment with the settings and see if it works.
2018-11-2
A CW
vasi Posted at 11-2 04:18
[view_image]
Stunning - in a word!
2018-11-2
DJI Gamora
Hi Vasi, thanks for reaching DJI Forum. We do appreciate sharing your photos here. Sad to say this really not easy to adjust or fix in any photo editors available because this will compensate for the quality of your photo. Try to avoid the brightness of the sun by lowering the shot or composing the pano shot avoiding the sun to its left (as I can see in the photo). Anyways, this picture is perfect for flying indeed. Have a safe flight always. Hope to see more photos from you Vasi.
2018-11-2
DPJ
Flight distance : 21686 ft
You could always try filters. Some go as low as ND16. If not, use manual exposure and shoot two photo's exposing for the two elements, then merge them.
2018-11-2
jacksonnai
Malaysia
[view_image]
Wow just wow
That was so amazing
2018-11-2
spookster
Looks like a great location and nice panoramas.
2018-11-2
DJI Panda
Flight distance : 405039 ft
Beautiful works!
2018-11-4
Jos A
Flight distance : 73209 ft
shoot on manual, set correct exposure on the sun, then lock AE, shoot sphere.
You can set lock exposure on a button
2018-11-5
A CW
[view_image]
Do you have any videos?
2018-11-5
MikB
Flight distance : 13346 ft
If you post using Kuula you can get some interesting effects using the sun
https://kuula.co/post/7lKTW
2018-11-5
Bing Err
Flight distance : 9249964 ft
Here fixed it. JK.
No really this is a common problem with Spark panos. I've combined two pictures together in the past. One with the sun overexposed, and one with proper exposure. But then there's lots of photoshopping involved. The Mavic Air and other drones lets you capture panos in DNG format (lossless raw image format), but unfortunately the Spark does not. So it doesn't leave you a lot to work with.
2018-11-5
Woe
Flight distance : 4129268 ft
Wow. beautiful shots.
2018-11-5
Flighty
Flight distance : 1977175 ft
Croatia
However,, beautiful shots,,,
2018-11-5
