Nancy SEO
Flight distance : 434849 ft
I'd completely forgotten I had a set of the low-noise props. I popped them on yesterday. I had a polar ND filter on the bird, and as soon as I lifted off and was doing pre-flight checks, I noticed the gimbal trembling. Then I got the Gimabal Shake error message.
I put the bird back down on the ground, removed the filter, fired her up and lifted off. Normal.
I swapped out props to the originals, put the ND filter on again, lit off the drone and lifted off. Normal ops.
Put the low noise props back on the drone, put the ND filter on again, powered up, lifted off, same gimbal shake and error message.
I gave up the combination at that point and just flew the props.
Anyone else ever had this particular combination? It's just a minor PITA. Just curious. Apparently the two don't play well together.
