A CW
Flight distance : 13926112 ft
Charissa Posted at 11-25 08:05
Was just wondering why it is available on apeture and shutter priority mode that is semi auto, but not on full manual mode?
Seems a bit like full manual, is then also just a semi auto mode. Not sure why DJI would do the settings like that. If it is possible to set it in the other modes, would have loved to also have the feauture in the manual mode.
You're effectively changing either the ISO, aperture or shutter speed in manual which in turn auto adjusts the exposure value to compensate for the core adjustments. When in auto you select the exposure value and the drone adjusts the priority of the other settings to compensate. Essentially, in auto your only focus is the exposure whereas in manual you are setting more specific priorities to control variables such as motion blur, depth of field etc. You obviously can not adjust the EV to zero then the shutter speed to double the frame rate and expect it to match - one or the other depending on your priority. |
