fans2c917c03
I have been having the same problem for about a month now. The first 10 seconds play fine then everything slows down.
It seems that it happens more on longer clips with high speed increases.
For instance, I speed the clip up 5x then render it to my iPhone, then when I play it, the first 10 seconds play at 5x (with the sound correct at 1x) and then the rest slows back down to 1x (with the sound at 0.2x). The file length shows correct on the iPhone (example 40 seconds) but when you play, it takes 3-4 minutes.
To confirm, before it is rendered out of the DJI app, it plays correct in the DJI editor at the correct speeds.
Any help on this same issue would be appreciated.
