completely discharged during loading via usb at a Winwows computer
903 5 2018-12-28
Heavenone
Flight distance : 3563 ft
Hello together,
loading my OP at a windows computer via usb ..after 2 hours it was completely DISCHARGED ....so battery normaly distroyed!!!!
It could not be started any more!!!!!
Please help!
2018-12-28
Ray-CubeAce
Laptop running on battery?
2018-12-28
DJI Gamora
Hi Heavenone, apologies for the troubles you had with your Osmo Pocket. Just to clarify, have you charged your Osmo through your PC? If yes, I asked this because you did mentioned it was completely discharged after 2 hours. Would be possible to charge your Osmo to a normal power outlet and see if the issue persist? May I also asked, what is your operation before this occurred? In normal use, Osmo Pocket can shoot 1080p 30 fps video continuously for 140 minutes. For more detailed information, kindly refer to the User Manual for your future reference. Please reach us again if you have concerns, we're here  to help. Thank you.
2018-12-28
Heavenone
DJI Gamora Posted at 12-28 12:19
thanks for help...
yes it was charged at a pc..with no battery..
it was able to charge it with anormal handy charger.....
2018-12-30
CubbyJonson
just plug it into the wall socket
2018-12-30
Ray-CubeAce
Heavenone Posted at 12-30 02:39
thanks for help...
Basically, don't do that. Make sure you are running a laptop on mains and that will charge the Pocket rather than drain it.
2018-12-30
