JJBspark
Flight distance : 12477300 ft
Hi zinedine48,
Had a look at your flightlog.
Your MP drifted in ATTI away from you.
If i calculate, assuming that after the last postion the connection failed....after 3 secs in ATTI an autolanding starts. My guess is flew / autolanded for about 540 meters in the direction approx 126.
So the orange marking is where it has landed. So start your search there and make your search area wider and wider....It must be there!
Good luck finding your MP!
If i may advice you, practise to use the little attitude / compass indiator to bring the drone back home. If height is OK (obstacles) YAW craft back to home direction and when that`s done apply fwd stick, see craft closing in (look at distance decreasing)
cheers
JJB |
