Aardvark
Flight distance : 384432 ft
I would update to the 02.00.0700 version again as there were known problems with 0106. Also make sure the RC is at V1.9.3 otherwise there will be transmission problems.
Regarding stability you could always carry out the aircraft and RC calibrations:-
There are five calibrations on the P4:-
1) Sensors (Using DJI Assistant 2 , latest version).
2) IMU (on a dead level surface)
3) Gimbal (just after IMU).
4) RC sticks (with aircraft off).
5) And compass (in an open area (not over steel reinforced concrete), away from ferrous materials or electromagnetic interference). Get one good calibration, and that should be all that is needed until informed by system or erratic flying that needs investigation. Note that any ferrous metals very close to legs (steel frame in desk, cutlery in kitchen drawer, windowsill strengthening etc) will generate a 'compass error', this does not mean compass needs recalibration. just move the aircraft away from source of interference.
