DJI Pilot (Android) Release 1.2.0
4619 8 2019-2-22
Asher Pogi
Flight distance : 338481 ft
Philippines
Before flying my M2E Dual last night, I noticed it downloaded and updated the DJI Pilot app (Android) to v1.2.0
I will be trying the following feature, as using the DJI Pilot "Flight Mission" feature is too challenging for me on a Samsung A7:
  • Supports KML Import for creating flight routes for Flight Mission.
    So I can now use Google Earth Pro to plan my M2E Dual flight missions.  However, I'm not sure if will properly import the KML waypoints (location, heading, altitude).  I will try a simple route over a clear, open area and report back.  I typically use Litchi, which does support the M2E Dual flight missions, but not changing image modes - visible, thermal and MSX.  I'm hoping the DJI Pilot's Flight Mission fully supports changing image modes -  visible, thermal (ISOTHERM, palettes) and MSX
Another change listed:
  • Optimizes the isotherm, palettes, and FPV features for Mavic 2 Enterprise Dual for a better user experience.
    Could you elaborate on the changes.  Specifically, I know many other M2E Dual users were asking support for FLIR's DroneSense in this thread:
    Thermal Analysis Software magic DUAL
2019-2-22
Asher Pogi
Philippines
I concluded it's much easier to use the Litchi Mission Hub (web based) and Android app than importing the KML file for DJI's Flight Mission.  I also discovered that it records both Visible and MSX as separate video files.  Didn't test the picture feature to see if it does same.
2019-2-22
sclose
Flight distance : 422559 ft
Asher Pogi Posted at 2-22 21:02
Has ANYONE been able to import a kml to the DJI Pilot App?   What's the trick?
2019-4-4
djiuser_KJU1nNUDTNF7
Colombia
sclose Posted at 4-4 08:05
No hay truco, solo cargar el archivo, he tenido problemas para configurar la cámara del M2E en camera custom
2019-4-21
Colombia
Que configuraciones hace en la cámara custom para M2E
2019-4-21
Unicks
Couldn't help noticing GSH's 205 (C-FNTR) in your avatar... you work for them or just a fan?
We have hands working for us that probably know that aircraft intimately.. AME's, not pilots!
Cheers.
2019-4-24
sclose
Unicks Posted at 4-24 12:00
Hi, I've flown with them a bunch in Northern B.C., working metal exploration in the mountains.  Good crew.  Nice catch!
2019-10-14
fans66952088
Flight distance : 163750 ft
don't function MSX
2019-10-16
djiuser_69eVXVyfZ1Ld
sclose Posted at 2019-4-4 08:05
This script will work if you are generating one or multiple plots at a time in a GIS application.  In this case I use QGIS.  The workflow is:
1.  create the layer containing the plot(s)
2.  if creating multiple plots, add an  id field to the layer as a calculated field using:  @row_number
3.  Export the layer as a KML
4.  Edit the script below in QGIS' python console to contain the correct path and name of the KML
5.  Run script
6.  In the same folder as the AllPlots.kml file will be numbered individual kml plot files ready for importing in a simplified KML format that DJI Pilot will accept
import re
path = 'C:/Users/.../Downloads/'
kml = 'AllPlots.kml'
with open(path+kml, 'r') as f:
    data = f.read()
found = re.findall("<Polygon>[\S\s]*?<\/Polygon>", data, re.M | re.S)
[open(path+str(i)+'.kml', 'w').write('<kml><Document><Placemark>'+found[i-1]+'</Placemark></Document></kml>') for i in range(1, len(found)+1)]
Assuming you are familiar with using QGIS or some other python enabled GIS, the main advantage/use case for this script is:
1. generating multiple plots at once
2. bypassing Google Earth (for efficiency)
2020-3-24
