ThatSparkGuy
Flight distance : 10981 ft
I have seen threads about flying the Spark without the app. I used the ⏸-Fn-Alt combo to start the motors as described. However, I still have some questions:
- What mode is the Spark essentially in without the controller? P-mode/Atti mode—does it even use GPS & GLONASS? If so, I assume RTH works & the flight will be as stable as with DJI GO (?)
- I understand the Spark will record media, but do I have to have the app open to insert the SD card i.e. will it format correctly?
- If there is a required firmware update, will the Spark take off without the GO app?
- Are there any serious downsides, apart from not being able to receive warning messages, of not using the app?
Any help appreciated.
