Mark The Droner
Flight distance : 2917 ft
Have you read your manual? You must read your manual at least twice before you attempt to fly.
From your description, it sounds like you lack the fundamental knowledge that a pilot needs to fly.
Everybody has red lamps in the front. If you don't have red lamps in the front, that is a good reason to worry. If you don't know this, that's another good reason to worry.
The first thing that must happen before you fly is you must have a home point marked. It's not mandatory, but it's a very routine and expected part of a Phantom flight. It is extremely unusual to voluntarily launch without a marked home point.
Once you have a marked home point, you know you had GPS even if for a few seconds.
If you have no home point, you should wait to gain adequate satellites so that you have GPS and a home point marked.
Blinking yellow lamps in the rear - different meanings depending on how fast they are flashing.
Slow flashes means you're in ATTI mode which means you have inadequate satellites for GPS, or you have deliberately selected ATTI mode.
Fast flashes means your controller's control signal is not connected to your P3 4K for whatever reason (out of range, not linked, etc.).
Everything said above is extremely fundamental and if any of it is new to you, you should stop everything, sit down, and READ YOUR MANUAL. Then read it again.
Good luck
