P2VP not connecting to satellites(not green)
3501 18 2014-11-11
deepan89
Singapore
Hi guys,
I recently got my P2VP & flew it a couple of times. It hasn't crash or drop ever since but lately it started to act strange. It doesn't lock GPS homepoint (Green LED) like before. The Phantom vision app requires me to calibrate everytime & still the LEDs are slow flashing yellow & at times yellow to red!
Like some of them posted here the support hasn't gotten back to me too. I'm a film student & I saved my money just to get this for my indie film making. Pls help.
2014-11-11
Gerry1124
How many satellites does it say you have on your app?
2014-11-11
deepan89
Singapore
Gerry1124 Posted at 2014-11-12 12:39
None bro
2014-11-11
Gerry1124
If you are not recognizing any sats on your iphone or whatever you are using, you won't get any green lights and no gps lock.  It sounds like your gps antenna has failed.  I would contact dji support or the dealer you bought it from.
2014-11-11
deepan89
Singapore
Gerry1124 Posted at 2014-11-12 13:07
If you are not recognizing any sats on your iphone or whatever you are using, you won't get any gr ...
I tried emailing them but no reply
0 connection
0 connection
2014-11-11
Gerry1124
deepan89 Posted at 2014-11-12 13:27
Ok, lets get rid of the simple mistakes first, then take it from there.  Have you had the shell or body apart?  Is this a photo while you are outside, or inside the house?  Have you painted the top or had some kind of decal tape over the top?  Have you had a hard landing before?
2014-11-12
DJI-Sophie
China
Please connect to the Assistant software, check is there any error message. Also, please check the Compass value is within the normal range or not.
2014-11-12
deepan89
Singapore
Gerry1124 Posted at 2014-11-12 18:01
Ok, lets get rid of the simple mistakes first, then take it from there.  Have you had the shell or ...
none of any above mentioned bro. Never crashed, no physical damage, nothing at all.
2014-11-12
deepan89
Singapore
DJI-Sophie Posted at 2014-11-13 09:10
Please connect to the Assistant software, check is there any error message. Also, please check the C ...
Is this abnormal? My P2VP is place on the table next to my com.
compass reading
compass reading
2014-11-12
Gerry1124
deepan89 Posted at 2014-11-13 12:30
Take it outside to see if you get any sats.  Inside my house when it is setting on my desk, I don't get any sats either.
2014-11-12
deepan89
Singapore
u mean bring my com out while my drone is connected to the Phantom software?
2014-11-13
Gerry1124
deepan89 Posted at 2014-11-13 16:02
Take your phantom outside with your transmitter like you were going to fly, without actually starting the motors.  Power on everything and see if your phone says you have acquired satellites.  When I power on the phantom inside, my phone says I have no satellites when I am inside, but I take it outside and pick up all of them.  Having your phantom inside will not pick up any satellites whether you are connected to the computer or not.  It has to have a line of sight to see the satellites.
2014-11-13
deepan89
Singapore
Gerry1124 Posted at 2014-11-14 02:17
Take your phantom outside with your transmitter like you were going to fly, without actually start ...
Yup, I tried it. Tried contacting DJI but their service sucks. I don't even understand what they mean too.
2014-11-20
kenargo
The image looks like the Phantom is inside a structure (home?).  If true then you won't get any satellites; take the Phantom outside, with a clear view of the sky and see if you get satellites.
Does your smartphone get satellites and GPS lock?  There are many free apps that will report satellite locks; I use them to test and verify.
2014-11-20
kenargo
Something else I noticed with my unit today that might help...
I had the same issue today, it was finding no satellites.  I knew I hadn't calibrated the compass so I did that and shortly thereafter the satellites where acquired.  I don't why they would be connected but it gave me the impression that an uncalibrated compass affects the unit reporting satellites.
2014-11-20
deepan89
Singapore
kenargo Posted at 2014-11-21 10:33
I had the same issue today, it was f ...
ok bro thanks alot I will try as you say
2014-11-21
jm87_vm06
deepan89 Posted at 2014-11-22 15:26
do you have any luck with your problem??
I have the same problem here no satellites on my phone but the only difference is that I can lock the gps home point
2015-2-25
deepan89
Singapore
jm87_vm06@hotma Posted at 2015-2-26 09:25
I have the same problem here no satellites on my phone bu ...
i tried after awhile it seems to be fine
2015-5-11
kirk2579
Flight distance : 37415 ft
are you sure that is not the couse lock you see set.
first set of green lights at 30 seconds is course (compass) lock...not gps
gps lock is second  set
2015-5-11
