disgusting work stabilizer
767 10 2019-5-29
Snarkvadim
Russia
Much time has passed since Ronin S came out and it is already obvious that there will be no firmware to fix shaky frames.
All tips come down to correcting the problem on the user side "calibrate", etc.
Will there be an official company statement about the failure of the stabilizer Ronin to work?
2019-5-29
Tima_007
Flight distance : 1110312 ft
Ukraine
All we get:
2019-5-29
Tima_007
Ukraine
All we get: Can you provide some short footage with issue, can you provide screenshot of balance test, motor parameter, etc... No other unswer! Newer! I think, first ronin's -S has some factory hardware problem, a lot of ronin's -S!  Ofcource, dji will newer tell us this but this is thrue.  Only in this forum many many ronin s users have issue thith non stable image, shaky footage ...
2019-5-29
Tima_007
Ukraine
А если говоря по русски то это просто неподобство! Я пользовался Ronin S пол года с камерой Sony A7sII, в ней есть встроенный стаб и я всеравно замечал что картинка плывет местами. Теперь перешел на Fuji XT3 в ней нет встроенной стабилизации и теперь это кошмар, это просто худший стабилизатор для видео, проще снимать с рук, результат не сильно другой! Вчера отправил свой ронин на родину, пускай что-то с ним делают. Сейчас сделаю пост с подборкой видео
2019-5-29
Tima_007
Ukraine
https://forum.dji.com/forum.php? ... p;extra=#pid1870318
2019-5-29
Snarkvadim
Russia
girl in the mask - do not ignore the messages of users of your products
2019-5-31
djiuser_t6RTMAIzeCc4
Latvia
Yes, i totally agree! If camera have IBIS, you can get smooth footage, but if you don't, like me and other users, footage is mostly terrible and you need to stabilize it in post.
Hope there will be some firmware update soon. DJI support team have not answered in any topic for a week or so, maybe that's the case?
2019-5-31
Snarkvadim
Russia
It seems to me that with heavy video cameras there is less shaking. I think that the problem is in very powerful engines, which do not allow light cameras to freely compensate the balance
2019-6-2
Ulysses
Flight distance : 573310 ft
Brazil
I tried changing the stiffness and it helped a lot. In fact, I did an Autotune with the high profile after I read a DJI adm post telling to raise the stiffness manually right before the motors start to make noise.
Did you try that?
2019-6-3
DJI Calam
Philippines
Ulysses Posted at 6-3 04:29
Did you try that?
Where can I change the stiffness? and what do you do with it? increase or decrease?
2019-6-4
Ulysses
Brazil
DJI Calam Posted at 6-4 06:07
Configuration > Motor Parameter.
Same page you do the Autotune
2019-6-10
