Mavic Pro - Focus Malfunction
1439 5 2019-5-29
Nath1199
Flight distance : 472625 ft
Issue:    Camera focus malfunction
Hi All,
My Mavic Pro has been completely operational for 18 months. No major crashes (or even minor crashes for that matter).
Recently I noticed that the horizon was not completely straight, so I completed a standard gimbal calibration through the DJI GO 4 app on my iphone. The calibration completed 100% and appeared successful. I shutdown the drone.
A few days later, I attempted to fly the drone at an outdoor location with good afternoon lighting. Immediately upon starting the drone and turning on DJI GO 4 app, I noticed that the camera was not focussing in auto-focus or manual. I attempted to reset camera settings while outdoors but this did not fix the issue. I turned focus to manual. I could see that the lens was not mechanically moving with the manual focus adjustment through the GO 4 iphone display. No focus adjustments whatsoever! [size=14.6667px]Frustrated, I shutdown the drone to look at it later when I got home
Looking at it later, I identified that once the drone is on, the lens is "frozen" at the position of shortest focal range. Focus is 5cm (2 inches) from the camera. The lens cannot be adjusted using either Auto-focus or manual-focus, therefore all photos and videos are blurry.
I then noticed that during drone shutdown and startup, the lens actually goes through a "self-calibration" and does move forwards and backwards before becoming "frozen" once more.
Video below of drone starting up. The lens can be seen moving during startup sequence (at about 7 second mark of video);
https://www.youtube.com/watch?v=_5ESqJ40KgI&feature=youtu.be
Anyway, I have completed the following troubleshooting steps;
  • Completed firmware upgrades
  • Completed IMU calibration
  • Completed second gimbal calibration
  • Completed camera reset settings through GO 4 app
  • Completed “restore factory defaults” through DJI Assistant
  • Uninstalled and  re-installed GO 4 app.
Nothing has worked. DJI have advised that the next step is sending it into the DJI repair facility. DJI also advised that I would be liable for the $60 per hour service fee plus any cost of parts. Thanks a lot.
THIS SEEMS TO BE A COMMON MALFUNCTION. See other examples at these links;
https://www.youtube.com/watch?v=hV2pAhtWs4w
https://www.reddit.com/r/dji/comments/8ijmke/mavic_pro_stuck_on_macro_focus_manual_or_auto/
https://forum.dji.com/forum.php?mod=viewthread&tid=140455
This is so disappointing and it is not reasonable to expect that a $2000 item of camera equipment will suffer major failure after 18 months.
Has anyone else had this issue resolved??? Did you have to send your drone away? What was the repair outcome?
Thanks in advance.
Nathan
2019-5-29
DJI Susan
Hi Nathan, sorry for reading the issue. For your situation, I sincerely suggest you start a case and send it in for a fully diagnosis: https://www.dji.com/support We'll offer you a proper solution according to the damage assessment, thanks!
2019-5-29
dirokol
Flight distance : 103881 ft
Russia
Same problem, any solution?
2020-1-12
Jason_M
Flight distance : 178816 ft
Did you have any luck getting this resolved?
2020-10-10
Jason_M
I have the same issue and have completed the same steps ;
I've had the drone now for I guess 18 months. It seems like the lens has completely failed and needs replacing.
2020-10-10
Jason_M Posted at 10-10 16:43
Hi Jason_M, sorry for the trouble with the drone, could you please upload a short original video to Dropbox or Google Drive and post the link here so that we could check and give further advice? Thank you in advance.
2020-10-11
