Rob W
Flight distance : 94390 ft
Sweden
I don't know that the SMC in DJI SMC Team means, sorry.
A Beta version is an unfinished software/firmware, it is a test version. Depending on what is new in the software/firmware, there can be more or less risk. For instance, are we testing new flight algorithms, or a picture filter that we can add to photos?
Generally, if you want to be on the safe side, only use official release versions. If you use your drone commercially and are dependent on it for your business, don't use betas on it. If you have a spare drone though, which you are not dependent on and you can live with occasional bugs, but you want to test bleeding edge functions, you can test a beta. But never, ever, use beta software if you are dependent on your drone and you can't accept bugs. There will be a high probability that there are bugs in the beta - maybe not risky all the time, but there will probably be bugs. |
