Propeller automatically turned on, and cut my finger.
1681 12 2019-6-29
Apollon
Flight distance : 243999 ft
Greece
Hi, as i was fixing the propellers, checking everything before i take off, one of the propellers boosted up, started working, cut my finger and stoped working. ( I did not have any connection to the remote controller it was inside the bag still ) not even connected to the phone.
Could somehow the wind make the propeller start ? I have no clue how did that happen.
2019-6-29
fans19db8551
Flight distance : 352851 ft
Singapore
wow that is weird.
2019-6-30
fans19db8551
Singapore
usually i would turn the remote on first as the normal sequence before the mavic to turn on. i think it's better to practice that protocol in the future even if you're not planning to fly.
i've been hit by both the stock and low noise props. i would say the low noise ones cut nastier with the thinner blades. I think at some point we all will get hit with the props.
2019-6-30
DJI Diana
Flight distance : 2408 ft
Hi, we are so sorry to read about your unpleasant experience with the unit. We sent you an email to further check on this. Please check later. Thank you.
2019-6-30
Lucas775
Flight distance : 50642090 ft
No idea what went wrong.  You should always check the props before turning on the drone.
2019-6-30
A J
Flight distance : 13926112 ft
Check the props before tuning on the drone and switch on the RC before the AC
2019-7-1
JohnDG
Flight distance : 1097270 ft
Belgium
Always start up remote before the drone. And switch off the remote as last.
2019-7-1
Apollon
Greece
JohnDG Posted at 7-1 03:11
the drone was not even on, thanks for commenting ..
2019-7-1
Apollon
Greece
A J Posted at 7-1 01:27
i was checking at the props, the drone was not even on while the incident happened.
2019-7-1
A J
Apollon Posted at 7-1 13:24
I see - that is caused by the wind catching the prop - leave the props folded when doing a compass calibration/handling the drone then when level on the ground unfold them before arming the motors.
2019-7-1
Brad Bilger
Flight distance : 14843274 ft
A J Posted at 7-1 14:51
Oh wow... I can't see the wind spinning a prop hard enough to cut a finger like that.  Unless that wind was a hurricaine.  I agree.  Leave the props folded while calibration, but I just can't see the wind spinning them that hard.
2019-7-4
A J
Brad Bilger Posted at 7-4 16:14
Check out youtube - those blades spin very fast indeed and enough to cut skin - and it doesn't need to be a hurricane
2019-7-4
AntDX316
Flight distance : 3394731 ft
Vid is prob fake.
2019-7-4
